Introduction: Easy IoT Weather Station With Multiple Sensors (enchanced 1)
This Instructable is only about adjustment necessary on source code of original Instructables, while I had problems to get it running. The main problem - I did not have all but only DHT11 sensor attached, the setup() was failing while other sensors were not found.
The hardware part is exact same as on original. I connected only termo/humid DHT11 sensor.
I had to make some adjustments to the Arduino sketch code (see next steps)
Also I tested 2 boards and everything worked the same (see images of the ESP boards):
a) ESP12E DEVKIT V2 (www.doit.am) (baud rate 115200)
b) NodeMCU AMICA www.nodemcu.com (baud rate 115200, despite on board written "use 9600")
Step 1: Arduino Configuration and Adjustments
1. downloading in Arduino IDE the board need to search for "NodeMCU" that download huge package. Select "NodeMCU V0.9" board for compilation, the same did worked well also when board "NodeMCU V1.0" was selected.
2. module ESP8622WiFi is not downloaded automatically with the boards. I downloaded it myself and to put into library/ESP8622WiFi (found here www.nodemcu.com and read READ.ME file inside)
3. need to download separately other sensor libraries:
for Adafruit_Sensor - library Adafruit Sensor Unified
for Adafruit_BMP085 - same library name
4. I've connected only DHT11 sensor, so when started, the reading of next sensor just reseted the board. Solution - I wrote a lot of #ifdef for all sensors and than it worked. Final source code is attached
Step 2: Arduino Enchanced Script
The original script Weather_station_for_instructables.ino needed multiple #ifdef so I stored a final one here
