Introduction: Easy Knit Tie
I have been wanting to try to knit a tie for a while now and with Father's Day coming up (it was when I started) I decided to give it a go. It's pretty easy to make and soft to wear!
Step 1: Supplies
All you really need for this project is yarn and a knitting needle, but I will tell you everything I used.
Supplies:
- Yarn (color and design of your choice)
- Size 9 Knitting Needle
- Measuring Tape
- Yarn Needle
- Paper Clips
- Tape
- Pen
- Real Tie (for reference)
Step 2: Knitting
This tie only involves knowing how to Knit, Knit 2 Together (k2tog), and Knit Front and Back (k# f&b). Just in case I am confusing, I will put in parenthesis how many stitches you should have at the end of a row.
Directions:
Directions:
- c/o 1 (1)
- k1 f&b (2)
- k2 f&b (4)
- k1 f&b, k2, k1 f&b (6)
- k1 f&b k to end (7)
- k1 f&b k to end (8)
- k1 f&b k to end (9)
- k1 f&b k to end (10)
- k1 f&b k to end (11)
- k1 f&b k to end (12)
- k1 f&b k to end (13)
- k1 f&b k to end (14)
- k1 f&b k to end (15)
- k1 f&b k to end (16)
Step 3: Continuing the Tie
Now you just have a lot of knitting to do. I kept track of how many rows I did, but you can also measure. It is a lot of rows, so I would suggest measuring. It is very helpful to just lay it on top of another tie to see how you are doing.
Before I went about knitting the rest of my tie. I decided to find out where and how much the tie decreased.
I found out the tie I was using as a guide was, at it's widest, 9.5 cm across. (This is where you should be right now after all of your knitting 2 together.) My tie decreased to 4 cm at it's slimmest. Af first I was going to decrease a stitch at each centimeter decrease, but then found I would only get down to (pretending the tie was 10 cm at it's widest) 10 stitches which is way to wide for the skinny part of the tie. So I decided to decrease every half centimeter. In this case, I would decrease down to 5 stitches. I used tape to mark where on the tie the width decreased.
Now to knit again:
*Note: cm and inche measurements may not match up because I just measured in cm and then flipped the measuring tape over to see the inches number. But these are just approximate anyway.
Now to knit again:
- knit 61 rows of 16 stitches. Until you are about 20.5 cm (8 inches) from the tip of the tie.
- k7, k2tog, k7 (15)
- knit 16 rows of 15 stitches. Until you are about 25.5 cm(10 inches) from the tip of the tie.
- k6, k2tog, k7 (14)
- knit 24 rows of 14 stitches. Until you are about 32 cm (12.5 inches) from the tip of the tie.
- k6, k2tog, k6 (13)
- knit 22 rows of 13 stitches. Until you are about 38 cm (15 inches) from the tip of the tie.
- k5, k2tog, k6 (12)
- knit 15 rows of 12 stitches. Until you are about 42 cm (16.5 inches) from the tip of the tie.
- k5, k2tog, k5 (11)
- knit 10 rows of 11 stitches. Until you are about 44.5 cm (17.5 inches) from the tip of the tie.
- k4, k2tog, k5 (10)
- knit 10 rows of 10 stitches. Until you are about 46.5 cm (18.5 inches) from the tip of the tie.
- k4, k2tog, k4 (9)
- knit 3 rows of 9 stitches. Until you are about 48 cm (19 inches) from the tip of the tie.
- k3, k2tog, k4 (8)
- knit 7 rows of 8 stitches. Until you are about 50 cm (19.75 inches) from the tip of the tie.
- k3, k2tog, k3 (7)
- knit 6 rows of 7 stitches. Until you are about 52 cm (20.5 inches) from the tip of the tie.
- k2, k2tog, k3 (6)
- knit 7 rows of 6 stitches. Until you are about 56.5 (22.24 inches) from the tip of the tie.
- k2, k2tog, k2 (5)
- knit 365 rows of 5 stitches. Until you are about 155 cm (60 inches) from the tip of the tie.
- k2tog, k3
- k2tog, k2
- k2tog, k1
- k2tog and bind off
Step 4: Your Done
Now you just need to wear your tie!
I know only one way to tie a tie, Four in Hand Knot. But you can find other ways here.
Enjoy your stylish tie!
