Introduction: Easy Knot Tying Instructions
Knot tying can be complicated. There are many kinds of knots, and it can be hard to figure out the best way to tie a knot and which knots to use. We want to help people learn to tie some simple knots for their own use. Here we have presented 3 different knots and easy steps for tying each of them that we want to share with you.
We have chosen the Figure-Eight knot, the Clove Hitch Knot, and the Sheet Bend knot. Each of these has its general uses; The Figure-Eight Knot is used as a stopper knot to keep rope from running out of retaining devices. The Clove Hitch knot is great securing lines and can easily adjust the position on the rope to allow for the rope to be let out more. Finally, the Sheet Bend Knot is great for joining 2 ropes together. In this instructable we will teach you how to tie these 3 simple knots like a pro.
1-2 pieces of rope or string
Step 1: Key Terms
Leading/Working End- The end of the rope used to tie the knot.
Standing Part- The part of the rope not active in knot tying
Bight- A U shaped section of rope
Step 2: Figure Eight Knot
The figure eight knot is one of the strongest knots that forms a secure loop. It is popular for both boating and rock climbing due to its grip. The knot got its name due to its shape.
Step 3: Identify Your Leading End
Like with any other knot, the first step to tying a figure eight knot is to identify your leading end of your rope. The leading end is the beginning of your rope.
Step 4: Create Your First Loop
The second step is to put your leading end over the standing end, creating a loop. This step will resemble a “P” shape.
Step 5: Create Your Eight
Take the leading end and put it underneath the standing part, creating an "8”
Step 6: Stick the Leading End Through the Top Loop.
Step 7: Tighten the Knot
Pull either ends of the rope tight to create the finalized figure eight knot.
Step 8: The Second Knot: the Sheet Bend Knot
The sheet-bend, also called a becket knot and a weaver’s knot/hitch, is a simple and important knot used for tying two pieces of rope, often of different diameters or rigidities, together. The sheet bend is considered one of the most essential knots to learn. It is a general use knot that is known for its simplicity and non-jamming properties.
Step 9: Form a Bight
Take an end of a rope and make a bight as shown below. The standing part should not be crossed with the leading end.
Step 10: Add Another Rope
Take the free end of another rope and pull it through the center of the bight.
Step 11: Wrap the Rope
Wrap the second rope around the bight. You can wrap it in either direction.
Step 12: Tuck the Rope Underneath
Once the wrap is complete, tuck the second rope under its loop.
Step 13: Pull Tight
Pull the ends of the rope tight to create the finalized sheet bend knot.
Step 14: The Final Knot: the Clove Hitch Knot
The clove hitch knot is a simple all-purpose hitch that is easy to tie and untie. The clove hitch knot can be useful for securing ropes to trees, posts, or poles. This quick and easy knot can help in a wide range of circumstances, but it can be unpredictable and come undone or tighten up at random.
Step 15: Create a Loop
Put your leading end under the standing part, creating a loop. Depending on how you look at it, this step will resemble a “P” shape.
Step 16: Form a Second Loop
Form a second loop by twisting the rope in the opposite direction of the first loop
Step 17: Put Your Loops Together
Put the loops together, placing the first loop in front of the second loop.
Step 18: Tighten the Knot
Pull the knot tight around an object of your choosing to create a finalized clove hitch knot.
