Introduction: Easy Light Show Box
Versatile Stage Lighting Fixture
Standard low cost system, that can power DIY fixtures !
- Simple and cheap project
- Input : DMX signal and AC 220V power
- Output : 12V regulated current
- Can light most of basic LED lights.
Step 1: First Design and CAD
Quick drawing to see how to arrange parts inside, and settle dimensions (here is the first design, with another power supply and a different box).
The box can be 3D printed
Step 2: Data and Electrical Connectivity
The device must be easy to set up (at the beginning of a party or event), be resistant to moisture, shock and dust.
- This is ensured by the plastic universal box (that can be 3D printed) and "waterproof" connections.
The connectivity is universal and similar to commercial fixtures :
- 3 pins XLR for the DMX in and out (panel mount)
- panel mounted IEC sockets (in and out for serial connection)
The 12V output is provided by a 8 pin aeronautical socket (don't buy it on amazon). The mass is common to reduce the number of wires.
Safe design :
- CE standard box
- No welding (except for your DIY fixture...)
- High current wires and protection by the power supply
Step 3: What's Inside
- The box is based on a RGBW 8 Channel DMX Controller, this board takes 5V to 24V as input and regulates the output by voltage variation. This means that this device is suitable for controlling LED strips.
- The power supply is a classic 12V 5A, regulated in current, designed to power LEDs.
- A voltage / current regulator can be added to perfectly match the design of the connected device.
Step 4: The Fixtures
The aim of this device is to be compatible with most DIY LED fixtures (<60W)
Some examples of DIY fixtures, easy to build :
- LED strip panels
- Light tubes
- Simple par cans
- Your imagination is the limit
Step 5: DMX Set Up in Freestyler Software
All the following steps are performed using freestyler, an open source DMX control software, that fits very well for simple DMX setups.
- Open Freestyler Fixture Creator
- Creating a new virtual fixture with parameters that fit with the real one (attribute each channel on the desired parameter/color)
- Don't forget to give an appropriate DMX address
- You can now set up and use your new fixture with Freestyler !
