Easy Litmus Strips
Introduction: Easy Litmus Strips
About: Hey everyone, I'm a CSS programmer currently working on an orbital satellite for instructables. I'm 13, and developing music and animation. Peace!
Have you ever wanted to test if your fruit and vegetables are really organic? Ever wanted to know if you've washed off all the nasty pesticides and fertilisers on that salad? The average human consumes up to two litres of pesticides every year, so litmus paper can be very useful in everyday cooking and of course, scientific experiments. Fortunately, making litmus strips yourself is very easy and cheap, and you can make as many as you want without having to repeat the process.
You will need:
Distilled Water (tap water works, just not as well)
Red Cabbage
Paper (acid-free, art paper works best)
Step 1: Break and Boil
Cut off as many leaves as you want, though you will probably only need about two or three. Then, place these leaves into a pot or deep saucepan. Then you can boil the distilled water, however make sure there is no water already in the kettle because this will contaminate the distilled water. Once the water has boiled, pour it into the pot. Cover the top of the pot with something, preferably a lid of some kind. This will speed up the infusion. Leave the infusion for about 15 minutes, but longer is better.
Step 2: Dip and Dry
The water should be dark purple-ish by now, if not leave it for a few more minutes. Place a few strips of paper in the post, before removing them with a glove and placing them on a large plate. You don't need to wear a glove, but distilled water is dangerous for your health if swallowed and it may still be hot. The strips shouldn't overlap, but you can dip as many strips as you like. Leave them to dry for an hour or so.
Step 3: Done and Dusted!
Your strips should be light blue/greyish. If not, they are either not fully dry or the infusion required more cabbage. If they are, congratulations! You have made litmus paper, ready for use on alkalis and acids. Alkalis will turn the litmus green, acids will turn it red. Be aware that you may need to leave the litmus to dry after a test to see the colour change. You also need to make a solution of the acid or alkali, a solid won't cause any change! This process can be performed with rhubarb instead of red cabbage, which turns brown in the presence of alkalis. This was my first instructable, so any feedback would be really helpful, and vote for the Build My Lab (Build Their Lab) contest would mean the world to me. Thanks, and follow me for more 'ables in the future!  (•‿•)
Build My Lab Contest
Be the First to Share
    • For the Home Contest
    • Big and Small Contest
    • Make It Bridge
      Make It Bridge
    6 Comments
    TheOriginalNerd
    TheOriginalNerd
    6 years ago
    Here's a silly question: what characters did you use to make that smiley face at the end of your instructable? It reminds me of Funko Pops and I collect them. I would like to make that smiley. Thanks in advance.
    Theoscillate
    Theoscillate
    9 years ago on Introduction
    True, but very often organic means "no fertilisers or pesticides whatsoever". But if they do contain natural fertilisers or pesticides, you are correct.
    kymyst
    kymyst
    I think you are confusing the words "neutral" and "natural". Neutral means neither acidic nor alkaline, and a neutral substance will not change the colour of litmus ( or in your recipe, the flavanoid colouring matter in red cabbage ). You seem to be saying that only artificial acids or alkalis will affect the pH. Natural fertilisers ( manure, etc ) can also produce high or low pH values, and you would need to use analytical chemistry techniques to tell the difference.
    Theoscillate
    Theoscillate
    kymyst: The pH of vegetables and such are affected by artificial pesticides and fertiliser. If they are natural fertilisers, you are right, it will not affect the pH content, so the food is organic by definition. dekyos: Distilled water contains no minerals, so it can absorb these minerals and electrolytes from our body. It is true that you would have to drink a large amount, but I would hate for someone to be injured making litmus paper. If I didn't mention the risk, someone may drink it as normal water, and be injured.
    kymyst
    kymyst
    Could you please explain how testing with litmus paper can tell whether fruit and vegetables are "organic" ? And how do pesticides and fertilizers affect litmus if they are neutral ? Your claims seem rather exaggerated. Litmus paper prepared in this way will indeed detect acids and alkalis, but will not tell you whether they are natural or derived from added chemicals. I would suggest that all fruit and vegetables ought to be washed thoroughly before doing this test to avoid misleading conclusions. Distilled water is only harmful if you drink a large quantity, there is no need to be afraid of a few drops.
    dekyos
    dekyos
    What do you mean, distilled water is bad for your health? Is there something in the red cabbage that becomes toxic when boiled?
    I see no materials in your instructable that would be considered hazardous to your health, please explain.
