Introduction: Easy Loomband Choker Necklace
In this instructable I will show you how to make a Loomband choker necklace.
I will show you how to make it in a few different ways.
Step 1: What You Need
What you will need:
1. Loom bands
2. Loom (optional)
3. C or S clips
4. Loom stick
1. Loom bands
2. Loom (optional)
3. C or S clips
4. Loom stick
Step 2: The Colour
Gothic- black or purple
Bright/fun: any light colour
Casual: blue, grey or green
Smoky: brown
Hipster: rainbow with a peace sign charm
Smoky: brown
Step 3: Making the Choker- Single
Look at photos for more info
1. Put a loom band on two of your fingers so they're both sharing one Loomband and twist the Loomband into an infinity shape.
2. Put another Loomband on top of that Loomband this time not in an infinity shape.
3. Pull the bottom Loomband over the top one each side one at a time.
4. Then go through the whole process again except make sure the first Loomband you put on two fingers of yours is the only one that is shaped as an infinity sign.
5. Adjust the choker to fit your neck and connect a S or C clip to one end and connect it to other end and remember it has to be tight but not too tight that it chokes you.
Step 4: Making the Choker Necklace- Fishtail
This is the exact same as the single except instead of only having two loom bands on your fingers you have three.
Make it long enough to fit around your neck, add a S or a C clip to one end of the choker and connect it with the other and your done.
Step 5: Finished!
Now that your finished here are some safety tips for when using loombands.
1. If your fingers turn red or purple or just get cold take the loom bands of your fingers immediately.
2. Do not hold loombands near your face when making them just in case a Loomband snaps and hits you in the face.
3. If you are allergic to something like latex then check on package of loombands that they are latex free.
