Easy Make PCB Board
Intro: Easy Make PCB Board
HI Guys I'm Steve From India
And Today i'm Going to Show to How To make a PCB Board.
Click Here to See The VideoSTEP 1: What You Need
STEP 2: Now Come to Work
I'll do step by step
- Print Out Your PCB layout in photo paper with Laser Printer Only
- Cut The Copper Clad in The Same size to match the layout dimension
- Now Put The Paper onto The Copper Clad and Press With The Hot IRON
- Now You Need a Bowl of Water
- Put The PCB into The Water Let it soak For Around 30 minutes
- Now carefully Remover The Paper From Board
- After Removing The paper
- You need to put some of Ferric chloride in a container with little water
- Now put the PCB into the Ferric chloride Solution
- After 20-30 minutes You Are done to take the PCB OFF
- Now clean the PCB with some water
- Now You Need a acetone and cotton ball to remove the black part
- After Doing that you need to drill The holes for The components
- Now Place your components and solder it
STEP 3: You Are Done
- Your PCB is Competed Your PCB will Look Something like This
8 Comments
warhawk8080 6 years ago
Can you share this design on OSHPark?
Very very cool!!!!
wstewl 7 years ago
Looks easy to do.
Should the photo paper be glossy or matte?
asadulhuq 7 years ago
You may use a page of a magazine paper instead. Though pages are already printed still you may print your lay out again on it with a laser printer! Now you need not to buy a photo paper!
Steve Willson Kujur 7 years ago
ChristianE53 7 years ago
Be sorry that you especially need a laser printer. Is there any way to do ist with an inkjet printer?
Keith0923 7 years ago
It's not a very reliable method but I still congratulate the author for coming up with the idea which is definitely in the spirit of Instructables.
amitb4 7 years ago
