Introduction: Easy Masquerade Mask
Learn how to make a super easy masquerade mask using a printable pattern. You can either make your own felt fabric for a unique look, or simply use felt to make this mask in just a few minutes.
It's a fantastic quick and easy Halloween costume or for a masquerade ball!
Step 1: Print Template
Print out the masquerade mask template and cut along the edge and cut out the eye holes.
Step 2: Trace Template
Place the template on the back of the fabric and trace around it with a pen or marker.
Don't forget to trace the eye holes!
Step 3: Cut Mask
Cut out the mask, following the traced pattern.
To make it easy to cut out the eye holes, fold the fabric in half at the eye. Then cut a small slit. Then put the scissors into the slit to cut out the rest of the hole.
Step 4: Glue on Ribbons
Use a glue gun to add a small drop of glue on one side of the mask. Attach the end of one of the ribbons. Repeat on the other side.
Step 5: Wear!
Once the glue has dries, your mask is ready to wear!
You can even take it an extra step and use glitter glue or fabric paints to decorate it further.
The pattern on this fabric was made by wet felting.
