Introduction: Easy Mitrelock Bit Set Up
About: retired carpenter
simple steps to set up a bench mounted mitrelock bit
because of the accuracy required when making these measurements it is advisable to have certain tools
height guage and callipers
the more accurate these tools are the more they cost however there is a wide range available in the shops/internet so get what will suit you
Step 1: Get Profile Dimensions
(please note all measurements shown are from my cutter and will probably be different to your cutter)
set bit into router table and form a profile of the cutter into a piece of timber
from this point on accuracy is vital !!
measure the width of the tongue and the depth of the tongue and grove
record dimensions (needed each time this cutter is set up)
(measurements from my sample work piece)
tongue/grove depth = 7.44 mm
tongue width = 3.65 mm
measure the thickness of your work piece
(my sample)
thickness 14.83 mm
for the distance of the fence to the edge of the top tongue (cutter width)
add the thickness of the work piece to the tongue width measurement and devide by two
14.83 + 3.65 = 18.48 mm divided by 2 = 9.24 mm
height of cutter above table (cutter height)
for height of the cutter add the thickness of the work piece to the tongue and groove measurement and devide by two
14.83 + 7.44 = 22.27 mm divided by 2 = 11.135 mm
Step 2: Set to Cutter Faces As Shown
useing the depth gauge adjust the cutter height from table to the top of tounge as indicated
likewise set the fence back from the tip of the cutter as indicated
if the measurements taken were correct then the joint will fit first time
Step 3: Joint Out of Alingment
run 100mm sample cut off 50mm fit togeather as shown
joint should look like this
if not measure accross joint where shown
measurement greater than thickness of work piece
calculate difference between this measurement and thickness of workpiece
devide by 2
cutter height increased by this ammount
measurement less than thickness of work piece
devide by 2
cutter height reduced by this ammount
make new profile and recheck
if flush then height is correct
from this point do not alter height of cutter
Step 4: Fence Position
run profile for right angle joint
picture one
measurement less than workpiece thickness
measure width where shown
devide by 2
fence position decreased by this ammount
picture two
measurement more than workpiece thickness
devide by two
fence position increased by this ammount
