Introduction: Easy Natural Home-made Scrub
These days we all need to do our best in keeping safe and staying healthy and with all the hustling and bustling of everyday life not only does it take a toll on our mental health but also our physical health. When I go out to buy groceries or run an errand, though I follow all the rules and use face mask and sanitation procedures, still, when I get home my hands and face feels dirty. Even way before this pandemic started I loved to come home and wash my face thoroughly with a natural scrub. It lifts my mood immediately whenever my skin feels fresh and clean. In this instructable I will teach you an easy natural home-made scrub recipe. The best part of it being all natural is that you can add it to your body or face wash and use it regularly or as many times as needed.
Benefits of this scrub:
-Improve blood circulation
-Remove dead skin cells
-Remove puffiness
-Improve texture of skin
-Reduce appearance of cellulite
-Gives skin a natural radiant glow
-Exfoliate and remove buildup (dirt,oil,dead skin cells, makeup)
-Antifungal, Antioxidant and Antibacterial
-Aids the treatment of dry skin
-Remove puffiness
- Tablespoon for measuring
- Air-tight container for storing scrub mix ( I used a recycled jam jar but you can use ziplock bags, mason jar or any plastic container with a cover to keep out any humidity)
Ingredients:
- 1 tbsp ground cinnamon
- 4 tbsp white sugar ( brown sugar can work as long as it is a medium coarse texture)
- 2 tbsp regular instant coffee
Tip: You can easily add coconut oil or any other essential oil for added benefits. Be careful to add it only to the scrub mix you will be using and add it only at the time of usage; since coffee and sugar will gradually melt when mixed with wet ingredients.
Ingredients:
Step 1: Measure and Mix
Use your tablespoon to measure out the ingredients and put them into your air-tight container. Cover and close the lid on container and give it a good shake so all ingredients are mixed together.
Step 2: Use or Store
Your scrub mixture is ready ! Congratulations! It was so easy and it is all natural so go ahead and pamper yourself by using it.
All you need to do now is place a spoonful of scrub mix into your hands and add a couple drops of your favorite face or body wash. You can use it on your hands or face or even all over your body, simply massage gently on skin in circular motions for at least 20-30 seconds. Rinse with water and start reaping the benefits of this amazing home-made natural scrub.
Tip: Don’t forget to store the remaining scrub mix somewhere with cool temperature and always use a clean dry spoon to avoid introducing any moisture to the mix
