Introduction: Easy Pandahall Tutorial - How to Make Handmade Blue and Red Glass Bead Bracelets
In this article, I want to share a handmade blue and red glass bead bracelet with you. Just follow the simple tutorial below to make one if you like this blue and red bracelet.
Step 1: Supplies Needed in DIY the Blue and Red Glass Bead Bracelet:
6mm Clear Bicone Glass Beads
6mm Red Bicone Glass Beads
6mm Blue Bicone Glass Beads
Platinum Memory Wire
Silver Eyepins
Platinum Lobster Clasps
Round Nose Plier
Diagonal Plier
Step 2: Make the First Part of the Blue and Red Glass Bead Bracelet
1st, combine a red, clear and blue bicone glass beads to a silver eyepin. Then, make a hoop on the other end of the silver eyepin. Refer to this step to make 5 more such bead patterns (as shown in the picture);
2nd, cut a part of platinum memory wire and make a hoop on one end (as shown in the picture);
3rd, add glass beads and the 6 bead patterns made above to the memory wire (as shown in the picture);
4th, refer to the above steps to add more glass beads and glass bead patterns (as shown in the picture).
Step 3: Make the Rest Part of the Blue and Red Glass Bead Bracelet
1st, make a hoop on the other end. Then, add a platinum lobster clasp to the other end (as shown in the picture);
2nd, cut another part of platinum memory wire. Then, make a hoop on one end and cross the wire through the glass beads and add more glass beads (as shown in the picture);
3rd, make a hoop on the other end and connect the two ends together through a platinum lobster clasp (as shown in the picture).
Step 4: Here Is the Final Look of the Blue and Red Glass Bead Bracelet.
Do you love this blue and red glass bead bracelet? The perfect combination of red glass beads, blue glass beads and clear glass beads makes this blue and red bracelet stunning. Try to make one by yourself if you like this blue and red bracelet.
