Introduction: Easy Paper Dispenser!
This is an easy paper dispenser. In school, I always need paper for things like notes, assignments, etc.
A pack of paper is hard to manage and can get messed up. Even in a binder, it would take too long to open and pull out.
So this is an easy dispenser you can make at home which produces paper quickly and easily for whenever you need it. :)
- Cardboard Roll (like the ones leftover when you empty a roll of tissue paper)
- Scissors
- Tape
- 2 or more pieces of any kind of paper (however many you need)
Optional Supplies:
- Stickers & Other Decorative Pieces To Decorate Your Dispenser
- Blank Piece of Paper
Step 1: Opening
Begin by cutting open your cardboard roll. This will be an opening for the paper to come out from. Try to make the cut as straight as possible.
If you want, you can lay out the cardboard flat and glue a piece of paper on it before cutting out the opening.
Step 2: Setting Up the Paper
Use very little amounts of tape to stick your paper together. It's up to you if you want to do it vertically or horizontally.
Step 3: Placing the Paper in the Dispenser
Roll up your long, taped up piece of paper and slide it into the cardboard tube. Don't roll it up fully, though, and leave a little bit open. The extra part should be corresponding to the opening. Then use tape to seal the dispenser.
Step 4: Finished!
This is the final product! Pull on the tab for paper! You can add stickers and other decorations if you want to. :D
