Introduction: Easy Paracord and Med Bottle Dog Poop Bag Holder
It's spring and time to do even more dog walking than usual!
Problem: broken poop bag dispenser! I buy these bags in bulk but they only come with one dispenser and the plastic attachment hook always breaks off. I also like to keep an extra roll or two in the car and backpack. Using poop bags without the dispenser always leads to a jumbled mess of bags. I wanted a few extra dispensers and noticed that prescription pill bottles are about the perfect size, so I thought I would fancy one up a bit with some paracord and add a durable attachment hook. Check it out!
- 2 6 foot paracord sections (I used 7' and had extra) (optionally 2 different colors)
- Prescription medication bottle
- Scissors
- Lighter
- Rubber band
- Large drill bit and drill (I used 1/2"). A Dremel tool or even an X-Acto knife would work too.
- Leash hasp, carabiner or keyring hook.
Step 1: Hitch Er Up!
I wanted to spice up my pill bottle with paracord and use it to allow me to hook the bottle to a dog leash or a backpack. After some research I found an easy paracord wrapping technique called Ringbolt Hitching. This technique uses two separate cords, I had two different colors available and I felt it would be easier to demonstrate the technique, but you could easily just use a single color.
- Start with 2 at least 6' cords (I used 7' to have extra to play with)
- Cut the ends and melt with a lighter to avoid fraying
- Start with the left cord,
- wrap cord around to the right
- create a loop
- fit the end under the loop
- pull tight
- pull end back to the left side
- Repeat for the right side
- wrap cord around to the left
- create a loop
- pull tight
- pull end back to the right side
- You can push the cord towards the lip at the top of the bottle and slightly adjust the cord to keep it tight and straight
- Finish the top and bottom off with a simple square knot.
Step 2: Finishing Touches
These steps might vary based on what you have and your needs. To make the hole in the cap, I used a 1/2" drill bit, but you could use a Dremel tool or even an X-Acto knife. I had the attachment hasp but you could use a simple keyring or just a loop of cord.
- Attach the hasp near the top of the bottle, again using basic square knot.
- Cut off excess cord. Melt the ends to avoid fraying.
- Drill a hole in the top to make for easy dispensing
With the finishing touches done, it's time for a walk! Enjoy and thanks for checking out this Instructable!
