Introduction: Easy Peasy Beesy Candles
Beeswax is magical. Beeswax candles burn bright, steady, and with the scent of honey. Here’s a really simple way to make one.
Step 1: Special Materials and Tools
A clean tin can with top removed and bent to make a spout. A small glass (like a shot glass or votive holder) from a thrift store. Wick, cheap online. I’ve had good luck with square braided wick, size #1. And of course, beeswax. Less than ten dollars a pound is a good price for beeswax.
Step 2: Melt the Wax
Break up your beeswax, place it in the tin, and melt the wax in simmering water.
Step 3: Make a Wick
Cut a piece of wick long enough to reach from the top to bottom of your glass container. Dip it into the melted wax and let it dry straight. (If you want to make a taper candle, repeat this a few hundred times.)
Step 4: Pour
Pour the (HOT!) wax into the container.
Step 5: Wait
Let the candle cool. Clean up the beeswax you spilled.
Step 6: Make Space for the Wick
Drill a small hole, sized for your wick, in the center of the candle.
Step 7: Insert Your Wick
Slide the wick in the hole, and trim the excess.
