Introduction: Easy-Peezy High Calorie Survival Bars
Here is the recipe for my favorite Survival "Calorie Bars".
Each 2 inch x 2 inch square has roughly:
600 calories
8g of fat
24g of protein
38g carbohydrates.
All in all, if you munch on these on the couch, you'll gain like 10lbs per week (I don't know that for fact and haven't actually done calculations to come up with that number)
These ARE meant to be eaten when you have NO OTHER FOOD. Even though they are tasty.
I'm going to take a quick break while these photos upload, maybe I can go and find my sewing machine.... Not for this project of course, I'm thinking about another project. Yeah I'm gonna grab my sewing machine, be back in a few.
Step 1: Step 1: Materials
You will need:
1 sauce pan or pot
1 timer
1 cookie sheet
1 mixing bow (That thing really wasn't made for mixing but I used it anyways
1 measuring cup (1 cup)
1 mixing spoon
Step 2: Step 2: Foods
You will need
Flax seed (optional)
Frosted Flakes (Or un frosted. 1 handful)
Oatmeal (3 cups)
Protein Powder (1 cup)
Peanut Butter (Creamy or Crunchy)
Olive oil (Or virgin/extra virgin olive oil. Regular olive oil does have more carbs)
Maple Syrup (Almost 2 cups)
Honey (A few teaspoons)
Peanuts (A hand full)
Raisins (A hand full)
Step 3: Step 3: Combine
Fill the measuring cup with syrup and pour into the sauce pan. Fill the second one almost all the way to the top and add honey until full. Add to saucepan.
Add 1/2 cup of olive oil to saucepan
Turn saucepan on lowest setting
After mixture is warm (Just a bit more than room temperature), begin stirring slightly for 5-10 seconds every 60 seconds until it is warm enough to melt the peanut butter
Add 2 massive spoonfuls of peanut butter (Continue to stir)
Stir until it feels like very soupy caramel (continue to stir for 5-10 seconds every 60 seconds to keep it from "Crusting" on the top)
Step 4: Step 4: Mix Dry Foods
Combine your dry foods (Description in pictures)
Step 5: Step 5: Combine and Bake
Preheat oven to 375 degrees.
Step 6: Step 6: Storage
Cut into 2 inch x 2 inch squares
Place cookie sheet into freezer for about an hour
Place 6 squares each into 3 vacuum seal bags for a total of 18 squares
6 squares = roughly 3 days of food @ 600 calories per square. 2 squares per day = 1200 calories per day. (1200 calories per day is not healthy but will keep you alive in dire situations. If you are planning a camping trip, plan and pack at least 2400 calories per day)
30 Comments
4 years ago
How long do they stay in the oven. 375 degrees seems very hot. Is that the right temperature
6 years ago
I just made my 21st. batch last night.... I have made them using almonds, walnuts, Acorns (properly leached, dried and crushed into small pieces) and with chocolate chips instead of nuts.... My favorites are the Acorn (white) and chocolate chip...
When making them with the chocolate chips increase the oatmeal by 1/2 cup or they will be runny... I cook them for about 15 minutes at 375 (just till the edges turn brown) and they work fine.
I have been storing them in vacuum bags in the freezer, but left some out to see how they would last and ate some the other day that were left out for 34 days, they tasted just like when they were made (and no ill effects) so they will last at least a month.... As far as syrup, I have only tried home made maple syrup from this past spring, so I am not sure how regular table syrup would work or how long they would stay good....
I am going to try leaving some out (in vacuum bags) for 3 months this time and will let you know how they hold up.
Reply 6 years ago
By the way, I also use only 3 table spoons of peanut butter, when I used 1c. they turned out very soupy.
7 years ago
Just made this and it turned out awesome. I used one and 3/4 cups syrup including the honey so it wont be as soupy as other comments stated and also added a little shredded coconut, dried cranberries as well as the raisins. Its solid but chewy and moist and taste good.
7 years ago
Those macros don't add up to 600 calories...
7 years ago
I'm not sure if this has already been addressed, but your pictures show pancake syrup but say maple syrup which behave in drastically different ways, hence the gloppy mess someone else mentioned that I have also unfortunately ended up with. I put in a ton of extra oats and 2 eggs to see what happens since these will be eaten quickly at my house - my hubby needs a quick load of calories at work so he doesn't lose weight. Going to try dark corn syrup next time instead to avoid the high fructose corn syrup but get a bar that holds together.
Reply 7 years ago
It sounds to me like the gloppy mess is probably due to the eggs and extra oats. That would definitely glop it up a bit.
7 years ago
i'd skip the raisins they aren't a fav of mine but otherwize this was awesome! :D
8 years ago on Introduction
Hi! I was just wondering how much does a 2 x 2" square roughly weigh? Also, if I would like to alter the recipe so that it's nut-free, do you have any suggestions for substitutes for the ingredients? Would it be okay to just completely take them out of the recipe or would it not work anymore? (ie. the peanut butter) And lastly, how long do you need to bake it for?
Thank you so much! (And sorry for so many questions)
Reply 7 years ago
If you can use sunflower seeds or pumpkin seeds, you can use them instead of the nuts.
I usually bake them @ 10-15 minutes until golden brown on top. I've heard soy bean/tofu works well in these but I've never tried it. You could also try other beans since they are also high in protein but I'm not sure how well they would work. If you do find something that works please post a link to your instructable and I'll add the link :)
8 years ago
You might add an additional "fiber" material, (like Metomucal). Something flavorless and in powdered form. Help in keepingthe bowels moving and functioning in duress situations.
Reply 7 years ago
another option would be the usage of wholegrain oatmeal :) the flax seeds also provide some amount of fiber
Reply 7 years ago
flaxseed meal goes rancid easily because of the high fat content; it would need to be refrigerated or frozen for long term storage. The flax needs to be ground else it just goes through undigested. You could use fine ground psyllium.
Great Idea! Thank you :)
8 years ago
9 years ago on Introduction
I'd like to try making this with virgin coconut oil instead of olive oil.
Try it and post your results! I know plenty of people whom prefer coconut oil vs olive oil, let us know if it makes the bars taste any better =)
My bars turned out nothing like the pictures. Four cups of dry to nearly 3 cups of liquid (counting the pb) just doesn't seem like enough to me. There was never a point where I had a dough, it was just very soupy, and I have some very chewy bars... I'm going to dehydrate them and hope for the best.
10 years ago on Introduction
How long will these last?
