Introduction: Easy Perfect Straight Cut Aluminum Sheet
Aluminum is an easy material to build cases cause it is good to work , but to get a good result is necessary some good tools. Sometimes simple techniques are enough to get a good final result , that is what i gonna show in this instructable .
Step 1: Material Required
stylet
set square
- aluminum sheet
Step 2: Cutting
Use set square and hold it tight , with the help of your other hand press and slide stylet until desired marked position . Once or twice is enough .
Step 3: Bent
Bent aluminum sheet to break it .
Step 4: Cut Comparisson
Comparing result is clearly better . Another cut on pictures were made with scissor .
