Introduction: Easy Pot Rack
About: Hi there! If you're here on Instructables, I bet we have a few things in common. Like me, you probably like fine food, great cocktails, and interesting stories. Almost as much as you love building stuff. S…
After an eternity of dealing with a closet with a big mess of pots & pans, I decided it was time to solve that problem once and for all.
Being, in the tradition of my favorite kinetic sculptor, Jean Tinguely, a bricoleur, the plan was to use objects I found around the house to make something useful. So, with an afternoon, a plank of wood and a couple of bits from Ikea I had lying around, I went to work. The chain, nuts & bolts I sourced from a local hardware store.
Step 1: What I Used...
In addition to the leftover stair tread I found in the garage, I used the following hardware:
  • 2x IKEA GRUNDTAL Rail, 20 3/4"
  • 4x Screw Eyelet, 5/16-18
  • 4x Bolt Eyelet, 1/4-20
  • 4x Nylock Nut, 1/4-20
  • 10ft. Light Duty Chain
Step 2: Pre-Drilling and Mounting the Rails
So it happened that I had a couple of those super-cheap GRUNDTAL rails bars lying around after moving, and since they're so stout and intended to be used with some pretty nice little S-hooks, I surmised that they'd be perfect for my pot rack.
I got started by assembling the rails, checking the length of the screws I had lying around for length (to ensure I wouldn't punch all the way through my plank) and marked them off.
As you can see, I predrilled the holes with my drill press and prepped them for the next step.
Step 3: The Hanging Eyelets
After checking the alignment of my drilled holes, I marked and drilled the corners for inserting the eyelets.
Because the eyelets were closed, I put them one by one in the vise and bent them open so that I could hang the whole business from the lengths of chain.
After that was complete, I screwed the GRUNDTAL rails into the plank, completing the pot rack.
Step 4: The Chains
After tracking down my bolt cutters, I snipped the 10' chain length into 4 2.5' sections. I left those long so that I could be sure I had some wiggle room in the final mounting. I also used a vise to bend them open to facilitate hanging them with the chain.
Step 5: Hanging the Pot Rack.
The next few steps are pretty self-explanatory. I used a stud finder to locate one of the ceiling joists above the drywall, then measured over 16", then 16" again. I drilled a pair of exploratory holes to be sure that the threads were going into wood above the drywall, and used a pliers to seat them in the holes I pre-drilled.
The chains were left a bit long so that I could check the height and make sure all of us could reach the pans before I cut the links and finalized the rack.
I hope you like this Instructable! Please feel free to ask any questions in the comments.
