Introduction: Easy Remove Scratches From Smartphone Camera Lens
In this Instructable, i’ll show you how to remove scratches from your smartphone’s camera lens at no cost and turn it into a quality one again.
Over the time, your photos begin to appear more and more blurry when using the camera. The most likely cause for this is a scratched camera lens. A scratched camera lens can considerably impact the quality of any photos that are taken. However, in most cases the scratches are not on the lens itself, but on its protective coating.
A decent fix I suggest is grabbing some toothpaste. You can simply remove these scratches by using toothpaste, but you want to gentle when applying and removing the toothpaste from your smartphone’s camera lens.
Step 1: Apply the Toothpaste
First, apply a very small blob of toothpaste on the rear camera lens and use a cotton bud to coat the entire lens.
Step 2: Remove the Toothpaste
Then use a microfiber cloth to remove the toothpaste.
Step 3: Ready!
If you now take a closer look, you should find that all the small scratches have vanished.
The most important thing to remember here is that you want to gentle when applying and removing the toothpaste, since you could potentially damage the lens even further with too much force.
