Introduction: Easy Smart Clap Lamp
This is a very lovely study clap lamp that you can build as a beginner or just for fun or as a gift.
Since its quite simple, I wont go much into details to spare you the boring stuffs.
The code you need, the STL 3D print files will all be attached for you to get straight to work and build this beauty.
If you find yourself stuck in anyway, you can always reach out to me for assistance.
I will also attach a video summary of full assembling as a guide just in case you have need of or learn faster watching videos.
Now lets get to business fast....
To build this easy Smart Clap lamp, you will need the following;
1. Arduino nano
2. Sound sensor
3. 3D printer
4. 220V to 5V power supply (phone chargers)
5. Relay
6. Light bulb (your choice)
Step 1: Schematic
The schematic is quite simple.
The diagram don't explain it well enough so I will elaborate it here simply.
Connect you Relay pin to Arduino Nano PIN (D10)
Connect you Sound sensor pin to PIN (D5)
That's it you ready to move to next stage
Connect it all together and test!!
NB: you can change the location of the PINs if you want, just update it in the code to reflect the change and it won’t be a problem at all.
NB: connect the positive 110-240V PSU in to the relay to the bulb, if you u doubt please ask for sketche
NB: WORKING WITH HIGH VOLTAGE CAN BE DANGEROUS, PLEASE SEEK ADVICE IF YOU ARE IN DOUBT TO AVOID BEEN ELECTROCUTED AND MISSING CHRISTMASS THIS YEAR.
Step 2: 3D Files
Here you have your 3D printed lamp parts to assemble.
Just snap it part in and it fits perfectly and tight enough, you don't need glue to hold it in place.
Few low quality printers may print low quality and in that case you might need to glue the parts if necessary.
All files will be uploaded at end of this write up.
Step 3: Assembling
Take your time to arrange all components to fit in perfectly to avoid the bottom of the base from not having the clearance to sit perfectly.
Cover the bottom part of the Lamp with a cut out plastic cover or card and glue to hold..
as you can see,
1. Pass the bulb cable through to the base
2. That means the lamp holder should be in place nicely
3. Solder all cables nicely and cable tire it to be in nice positions
4. Use hot glue if necceaasy to hold the PCB boards to the base if necessary
Now you almost done!!!! lets finish up
Step 4: Beauty Is Set
Here you are done and dusted with this beauty.
Time to study and snap your finger for a light.... hehehe
Step 5: Final Files
All files attached now.
To watch a video summary of full assembly, please use the link below
Link to video of the lamp below
https://www.instagram.com/p/CUMXPjbLiAJ/?utm_mediu...
Thank you all, if you able to build it, give hi five let me see yo...... enjoy you day
