Introduction: Easy Talking Skull With Micro:bit - Remote Control Animatronic Skull DIY
They think treat, we think trick!
This DIY talking skull project can be controlled from afar so that you can prank your trick-or-treaters. They'll think it's a store-bought Halloween display, but then when it starts to say things that could never have been pre-recorded, they'll think it's possessed and run away!!!!!
Every talking skull project is a bit tricky, but this one is designed to be simple to build and fun to play with! If you have a drill, some zip ties, and a few fixtures from the hardware store, the project can be put together pretty easily.
The skull can be found on Amazon, and although a bit pricey, the quality is high and it's easy to drill the holes into it. The electronics in the talking skull are a micro:bit, a Bit Board, a servo motor, 10mm LEDs, and a battery pack, and these components are connected using zip ties as well, so connecting everything is quick.
The diagram below shows how the project works. Happy Haunting!
- Skull: Life Size Anatomical Human Skull Head - Detached Mandible and Skull Cap
- 2 micro:bits
- Crazy Circuits Bit Board
- Brick Compatible 270 Degree Servo
- LEGO Beam
- 2 AAA Battery Holders
- Jumbo Diffused LEDs
- Jumper Wires
- Zip Ties
- Fishing Line
- PVC Pipe
- Electrical Tape
- Flange Fittings
- Plastic Cauldron
- Wig
- Foam Core
- Speakers
- 2 Cell phones
- Halloween Candy
You will also need a Hot Glue Gun and a Power Drill.
As an Amazon Associate, I earn from qualifying purchases through some of the links above.
Step 1: Build the Circuit
Watch the video above for an overview of the project.
- Place the micro:bit into the Bit Board.
- Connect the servo to Pin 13. Insert the LEGO beam onto the top of the motor.
- Connect LEDs to Pins 15 and 16 using jumper wires.
- Plug in the Battery Pack.
Step 2: Add LEDs to the Eyes
- Disconnect the LEDs temporarily and thread the jumper wires through each eye.
- Hot glue the LEDs in place.
Step 3: Attach Circuit to Skull
Drill holes in the skull to attach the components as shown:
- Position the motor so that the LEGO beam moves freely through the hole in the neck.
- Position the Bit Board above the eyes, using zip ties that go through the jaw and connect to the holes in the Bit Board (as shown in the video).
- Position the battery pack in the front of the skull. Use mounting tape to secure.
Step 4: Attach Jaw to LEGO Beam
- Tie a piece of fish line to the spring's screw in the lower jaw. Tie the other end to the LEGO beam.
- Make sure the fish line is tight.
Step 5: Code the Micro:bit: Skull 'Bit
- Download this code to the micro:bit in the skull.
- This code receives the microphone volume and moves the jaw open when it's particularly loud, and closed when it's quiet. The eyes turn on and off in the same way but with more sensitivity.
Step 6: Code the Micro:Bit: Prankster 'Bit
- Download this code to a second micro:bit, and plug in a Battery Pack.
- This code listens to the volume of your voice using the on-board microphone and sends that value to the skull micro:bit.
Step 7: Embellish the Eyes
- Use a large blob of hot glue on the back of a glass dome to cover the LEDs in the eyes as shown.
- Use a hole punch to punch out a circle from black paper and glue it to each eye.
Step 8: Connect a Pole
Drill four holes in the skull and a PVC pipe, then connect the pipe as shown with zip ties.
Step 9: Make a Cauldron Candy Dish
- I used a flange and pipe fittings from the hardware store to make a connection for the pipe.
- Secure the flange to the plastic cauldron by drilling holes and connecting with zip ties as shown.
- Make a platform for the candy to sit on with two layers of foam core and a slit for the pipe to go thru. Then, cover the slit with black paper so the candy doesn't fall down!
Step 10: Add a Sign
- Make a sign out of cardboard and paint.
- Attach it to the cauldron with wire.
Step 11: Add a Wig
Step 12: System Setup: Phone Call and Radio
- Place speakers inside the cauldron and connect a phone.
- Make a phone call between this phone and another phone to provide the audio for the skull.
- Hold the prankster micro:bit up to your mouth while talking and the volume of your voice will make the jaw move.
*As an alternative to using two cell phones you could use a pair of walkie-talkies or two-way radios.
