Introduction: Easy Textured Crochet Blanket
Crochet blankets are fun and easy to make with Bulky and Chunky yarn because they work up really fast. Bulky yarn crochet blanket patterns are the absolute best blankets to make. Another thing about crocheted bulky blanket patterns that makes them great is they are usually made of simple alternative stitches that gives them a beautiful texture and soft and super cozy feel.
Today am sharing the pattern for this Easy Textured Crochet Blanket. This blanket pattern is made up just only Double Crochets and Front Post Double Crochets. Using bulky yarn makes this blanket a quick crochet project. This would also make lovely handmade gifts. If you are on the hunt for a quick DIY gift , then look no further. This blanket is perfect for gift giving or make one for yourself for snuggling up.
40 inches- Customizable to any size
Visit https://rajiscrafthobby.blogspot.com/2022/04/easy-textured-crochet-blanket.html
10 Ply Cotton Bulky Yarn
6 mm Crochet Hook
Step 1:
Here is the Video Tutorial:-
You can follow along with this tutorial video. Please be sure to subscribe too!
Step 2:
Round 1:-
Start with a Slip Knot.
Chain 100 + 1 Chain for the turning chain.
This measures around 40 inches.
You can adjust the size of the blanket by altering these stitches according to your requirement.
Step 3:
Round 2:-
1 Double Crochet in the Second Chain from the hook.
1 Double Crochet each in the remaining stitches.
Once you reach end, Chain 2.
Straight Edge Turning Chain:-
Usually you would Chain 2, turn and start working the next round. Here is a quick tip to have a nice straight edge .
- Insert the hook into the 1st chain from the bottom.
- Yarn over and pull up a loop. You should have 2 loops on the hook.
- Turn your project and insert the hook into the first stitch.(the first Double Crochet)
- Yarn over and pull up a loop. You will have 3 loops on the hook.
- Again, yarn over and pull through 2 loops. You will have 2 loops on the hook.
- Lastly, yarn over and pull through 2 loops.
- This will make one Double Crochet.
Step 4:
Round 3:-
(1 Double Crochet is already made while making the turning chain)
1 Double Crochet in each stitch.
Once You reach the end use the Straight Edge Turning Chain explained in the previous round to make the turning chain.
Step 5:
Round 4:-
1 Front Post Double Crochet in next stitch.
Repeat(1DC, 1 FPDC)
Once You reach the end use the Straight Edge Turning Chain to make the turning chain.
How to make a Front Post Double Crochet...??:-
Yarn Over and insert your hook from front to back to front around the post of the next stitch.
Finish the stitch as the normal Double Crochet , i.e .Yarn Over and pull up a loop, Yarn Over and pull through 2 loops on your hook, Yarn Over and pull through remaining two loops on your hook.
Step 6:
Round 5 Onwards:-
Keep Repeating Round 3 and Round 4 untill you reach the size needed.
