Introduction: Easy Textured Crochet Long Table Runner
About: Hello all!!!! A warm Welcome and It's a pleasure to have you here. Art and Craft is my passion .I love experimenting new and creative ideas.
If you are looking for a quick way to add a touch of elegance with handmade creation to your home , then you have come to the right place. Crocheted Decor Handmade Projects are the best to add that personality to your space and Crocheted Table Runners are awesomely wonderful to add that touch. A Crochet Table Runner is a splendid way to add a little something of yours to the Dining or Coffee Table.
Today am sharing the pattern for Easy Textured Crochet Long Table Runner. Its a quick and easy Two Row Repeat pattern. The patter uses the basic stitches . You just need to know Single Crochets and Double Crochets and you are good to go. The Double Crochet Cluster Stitches creates the lovely subtle texture that somewhat resembles a Clover Flower.
Base - 8 inches - Customizable to any size
Length - Customizable to any size
Visit https://rajiscrafthobby.blogspot.com/2024/08/easy-textured-crochet-long-table-runner.html
4 Ply Cotton Knitting Yarn
4 mm Crochet Hook
Step 1:
Here is the Video Tutorial:-
You can follow along with this tutorial video. Please be sure to subscribe too!
Step 2:
Round 1:-
Start with a Slip Knot.
Chain 45.
You can adjust the size by altering these stitches according to your requirement.
Start with any multiple of 5.
Step 3:
Round 2:-
1 Single crochet in the Fifth Chain from the hook.
Chain 3.
3 Double Crochets in the same stitch(i.e. Into the same 5th Ch from the hook)
Skip 4.
In the next Stitch make- (1 Single Crochet, Chain 3, 3 Double Crochets in the same stitch).
Skip 4.
Repeat((1SC,Ch3,3DC)-all in the same stitch),Skip 4)
1 Single Crochet in the last stitch.
Once you reach end, Chain 2 and Use the Straight Edge Turning Chain to make the Turning Chain.
Straight Edge Turning Chain:-
Usually you would Chain 2, turn and start working the next round. Here is a quick tip to have a nice straight edge .
  1. Insert the hook into the 1st chain from the bottom.
  2. Yarn over and pull up a loop. You should have 2 loops on the hook.
  3. Turn your project and insert the hook into the first stitch.
  4. Yarn over and pull up a loop. You will have 3 loops on the hook.
  5. Again, yarn over and pull through 2 loops. You will have 2 loops on the hook.
  6. Lastly, yarn over and pull through 2 loops.
  7. This will make one Double Crochet.
Step 4:
Round 3:-
(1 Double Crochet is already made while making the turning chain)
Chain 2.
1 Single Crochet into the Chain 3 from the previous round.
Chain 2.
1 Double Crochet Cluster stitch into the next Single Crochet.
Chain 2.
Repeat(1SC(into the Ch3 Sp),Ch2,1DC Cluster(into the SC),Ch2)
1 Double Crochet in the last stitch.
Chain 1 and turn your project.
How To Make a Double Crochet Cluster Stitch....???:-
  1. Yarn over, insert the hook into the stitch, yarn over and pull through 2 loops on the hook.(This is same as doing a Double Crochet Stitch. It is just that , you don't finish the Double Crochet Stitch and continue doing the first part of the Double Crochet Stitch again and again).You should have 2 loops on the hook.
  2. Yarn over, insert the hook in the same stitch, yarn over and pull through 2 loops. You should have 3 loops on the hook.
  3. Continue with the first part of Double Crochet stitch untill you have 4 loops on the hook.
  4. Yarn over and draw the yarn through all 4 loops on the hook.
  5. Chain 1.
Step 5:
Round 4:-
1 Single crochet in the First stitch.
Chain 3.
3 Double Crochets in the Chain 2 space.
Skip the next Chain 2 space
In the next Chain 2 space make- (1 Single Crochet, Chain 3, 3 Double Crochets in the same stitch).
Skip the Chain 2 space.
Repeat((1SC,Ch3,3DC)-all in the same Ch2 space),Skip the next Ch2 space)
Step 6:
Round 5 Onwards:-
Keep repeating *Round 3 to Round 4*  untill the size needed and weave off.
