Introduction: Easy Thingspeak Home Weather Station (Hygrometer) With ESP8266
This project will utilised an API request method through ESP8266 as the client and Thingspeak Channel as the server. The purpose is to send data of your home temperature and humidity surroundings into the statistic display website which you can check anytime and anywhere.
Amazon Discount Price:CNT5 or DHT11 Humidity Sensor
Ebay Discount Price:
- CNT5 or DHT11 Humidity Sensor
- Jumper Wire
- ESP8266 NodeMCU CP1202
- OLED I2C 1280x64 Display
- Passive Buzzer Piezo
Ebay ESP8266 Weather Station Full Package
Software:
Step 1: Constructing the Home Weather Station
Step 1:
Attach the following jumper wire into the following GPIO pins shown on the image.
Step 2:
Connect the humidity sensor with the following ground, power and signal pin.
Step 3:
Connect the oled screen of scl and sda pin based on the ESP8266 pinout diagram.
Step 2: Installing the Required Library
Install The Following Library Into Your Arduino IDE:
- ESP8266_WiFi.h
- WiFi_ClientSecure.h
- Thingspeak.h
- neotimer.h
The other header file were created inside the Arduino Sketch for later on. You don't need to worry about the unincluded list, just keep follow the building steps and you will understand it.
Step 3: Setup the Thingspeak Channel
Setup Your Thingspeak Account
Go to the Thingspeak website and create a new channel.
- After creating new channel, setup your channel field in the channel settings.
- Then, from the API Keys menu you could copy your channel write api key and read api key along with your channel id for later use.
Step 4: Start Programming the Sketch
Step 1:
Create the extra 3 header file shown in the image.
Step 2:
Alternative Full Documentation is on my GitHub Page.
On the main file .ino, Copy the following sketch:
#define TS_ENABLE_SSL // For HTTPS SSL connection
#include <ESP8266WiFi.h>
#include <WiFiClientSecure.h>
#include "displayOLED.h" //Header file of setting up the OLED display 128 x 64 0.96 inch
#include "secrets.h" //Header file of your channel security information
#include "dhtfile.h" //Header file for the temperature sensor
#include "ThingSpeak.h" // always include thingspeak header file after other header files and custom macros
#include <neotimer.h> //Library for the watchdog Timer
char ssid[] = SECRET_SSID; // your network SSID (name)
char pass[] = SECRET_PASS; // your network password
int keyIndex = 1; // your network key Index number (needed only for WEP)
WiFiClientSecure client;
Neotimer mytimer;
Neotimer recTimer;
unsigned long myChannelNumber = SECRET_CH_ID; //variable for channel id
const char * WriteAPIKey = SECRET_WRITE_APIKEY; //variable for write api key
const char * ReadAPIKey = SECRET_READ_APIKEY_COUNTER; //variable for read api key
// Initialize our values
int number1 = 0;
int number2 = 0;
String myStatus = "";
// Fingerprint check, make sure that the certificate has not expired.
const char * fingerprint = NULL; // use SECRET_SHA1_FINGERPRINT for fingerprint check
int val1;
float val2, val3;
int buzzPin = 14;
void setup() {
start_connection();
recTimer.set(5000); //Timer for requesting value of output data from the website
mytimer.set(5000); //Timer for sending value of output data into the display website
recTimer.start(), mytimer.start();
void loop() {
// set the fields with the values
ThingSpeak.setField(1, number1); //order of the output
outputDHT();
if (recTimer.done())
Serial.println("Retrieve Timer Finish \tGetting Data...\n");
recTimer.stop();
number2++;
ThingspeakGetData();
runTimer("Get", 2); //set timer run 2 minute each to get data from the Thingspeak Channel
if (mytimer.done())
Serial.println("Send Timer Finish \nUploading Data...");
mytimer.stop();
number1++;
ThingspeakStatData();
runTimer("Send", 10); //set timer run 10 minute each to send data from the Thingspeak Channel
sendTrigger();
void start_connection()
Serial.begin(115200);// Initialize serial
delay(3 * 1000);
Serial.println("\nPerforming Starting Mode");
pinMode(buzzPin, OUTPUT);
HT.begin();
WiFi.mode(WIFI_STA);
if (WiFi.status() != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(SECRET_SSID);
while (WiFi.status() != WL_CONNECTED) {
WiFi.begin(ssid, pass); // Connect to WPA/WPA2 network. Change this line if using open or WEP network
Serial.print(".");
delay(5000);
Serial.println("\nWiFi Connected");
if (fingerprint != NULL) {
client.setFingerprint(fingerprint);
else {
client.setInsecure(); // To perform a simple SSL Encryption
ThingSpeak.begin(client); // Initialize ThingSpeak
if (!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
Serial.println(F("SSD1306 allocation failed"));
for (;;); // Don't proceed, loop forever
display.setTextColor(SSD1306_WHITE);
display.clearDisplay();
int yA;
for (int x; x < 30; x++)
yA += 8;
display.drawLine(0, 0, 150, yA , SSD1306_WHITE);
display.display();
delay(10);
tone(buzzPin, 600);
delay(500);
noTone(buzzPin);
delay(1);
void ThingspeakStatData() //verivfying the data output before sending into the Thingspeak Channel function
int x = ThingSpeak.writeFields(myChannelNumber, WriteAPIKey);
if (x == 200) {
Serial.println("Channel Update order" + String(number1) + " successfull."); //Updating channel status to inform order of overall channel update
else {
Serial.println("Problem updating channel. HTTP error code " + String(x)); //Issue with updating channel
void ThingspeakGetData() //Getting data from the Thingspeak Channel function
int statCode = ThingSpeak.readMultipleFields(myChannelNumber, ReadAPIKey);
if (statCode == 200)
val1 = ThingSpeak.getFieldAsInt(1);
val2 = ThingSpeak.getFieldAsFloat(2);
val3 = ThingSpeak.getFieldAsFloat(3);
Serial.print(String(number2) + ". Output Num:" + String(val1));
Serial.print("\tTemp Celcius:" + String(val2));
Serial.println("\tHumidity:" + String(val3));
else {
Serial.println("Problem reading channel. HTTP error code " + String(statCode));
void outputDHT() //sending output of the temperature into the Thingspeak Channel function
tempC = HT.readTemperature();
humid = HT.readHumidity();
ThingSpeak.setField(2, tempC);
ThingSpeak.setField(3, humid);
String myStatus = "Successfully Updating Value";
ThingSpeak.setStatus(myStatus);
display.setTextSize(2);
display.setCursor(x0, 0);
display.print(F("Hygrometer"));
display.setTextSize(1); // Draw 2X-scale text
display.drawLine(4, 18, 118, 18, SSD1306_WHITE);
display.setCursor(x0, 24);
display.print("Celcius: " + String(tempC) + "C");
display.setCursor(x0, 36);
display.print("Humidity: " + String(humid) + "%");
display.setCursor(x0, 48);
display.print("Made By M.Irsyad.Y");
display.display();
delay(50);
void runTimer(String Mode, int i) // function for watchdog timer without interrupting the next program
if (Mode == "Send")
i = i * 1000 * 60; //Minutes
mytimer.set(i);
mytimer.start();
if (Mode == "Get")
i = i * 1000 * 20;
recTimer.set(i);
recTimer.start();
void sendTrigger() //Trigger Passive Buzzer Function
for (int i = 0; i < 2; i++)
tone(buzzPin, 800); delay(150);
noTone(buzzPin); delay(15);
Step 3,4,5:
Copy the following sketches from each header file
1.For dht.h file
#include <DHT.h>
#define Type DHT11
int DHTpin = 0;
float humid, tempC, tempF;
DHT HT(DHTpin, Type);
//Coordinated Configuration:
int x0 = 8;
void getTemp_Display()
tempF = HT.readTemperature(true);
2.For displayOLED.h file
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// On an arduino UNO: A4(SDA), A5(SCL)
// On an arduino MEGA 2560: 20(SDA), 21(SCL)
// On an arduino LEONARDO: 2(SDA), 3(SCL), ...
#define OLED_RESET 3 // Reset pin # (or -1 if sharing Arduino reset pin)
#define SCREEN_ADDRESS 0x3C ///< See datasheet for Address; 0x3D for 128x64, 0x3C for 128x32
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
3.For secrets.h file
#include <Wire.h>
Step 5: Check Your Thingspeak Channel
You can check your channel after you succesfully upload the program into your ESP8266. There are extra visualisation you can add and use. For more information you can check the Thingspeak documentation library from ESP8266.
Step 6: Enjoy Your Project
If you have any inquiries or issue feel free to drop a comment below or dm me in instagram at @techwithbob so we can discuss the issue. Don't forget to leavee a like and subscribe to my Youtube Channel for more awesome project.
