Easy Way to Clean Gutters
Intro: Easy Way to Clean Gutters
We have a lot of trees on our property, and I've grown weary of having to get out my ladder each spring and clean the leaves from my live oaks out of the gutters. This year I had a brainstorm, and this brainstorm and $9 worth of plumbing parts has made this chore much easier. I decided to make an extension to my leaf blower, and in this Instructable are the steps needed to build such an extension.
STEP 1: Make Adapter for Blower Nozzle
There were two plumbing elbows in the kit I bought and I only needed one. I took the extra elbow, sawed off one end (leaving 1.5 inches of straight pipe). I heated this end (the sawed off portion) and squeezed it in my vice until its shape matched the nozzle of the blower's nozzle. It took about three tries to get it to match, but it was not difficult. I would heat the entire end, squeeze it in the vice until cool, then heat each side independently and squeeze them until I had a good fit.
STEP 2: Assemble Extension
Assembling the extension was easy. I simply inserted the straight pipe into the remaining elbow and used the included collar to tighten them together.
STEP 3: Attach Adapter to Blower
My original plan was to simply duct tape the adapter to the blower. Well, that was an amazingly bad idea! I quickly realized I needed a more firm way to put this together.
I took two pieces of aluminum flats from my scrap pile and attached them to the front and back of the blower tube using machine screws and nuts. You want to make sure there is no space between the adapter and the blower tube. You can see on the 3rd photo that I had to use needle nose pliers to insert the screws inside the blower tube.
I did this on both the front and the back, then attached the metal pieces to the adapter (photos 4 & 5). I inserted the machine screws from the inside, because when I want to use the blower for general yard duty, I can remove the adapter and simply leave the screws (and nuts) in place for the next time it needs to do gutter duty.
STEP 4: Attach Extension to Adapter
The final step was to attach the assembled extension to the adapter. Because of the screws in the adapter, I couldn't insert the extension fully into the adapter (it would only go in about an inch). I glued these parts together, then added 4 sheet metal screws to insure it would stay solidly together.
STEP 5: The Final Product
This extension to my blower has worked like a charm. It is easy to use, works great, and is solid. I originally thought I might need to use duct tape where the adapter joins the blower tube, but it has been unnecessary. I also thought I might need to make a nozzle at the end of the extension, but so far I don't think it is needed.
This was not a difficult project, and it is easy to change from a regular landscape blower to a gutter blower.
26 Comments
spiritwalker6153 1 year ago
ruggiero.michael.sr 12 months ago
dwieland 1 year ago
MrsWilson46 1 year ago
dwieland 1 year ago
CharlesD82 1 year ago
charlessenf-gm 1 year ago
However, to get the highest in high pressure gutter washing wands you'll want a pressure washer.
There are some really interesting attachments I found googol'ing the phrase "garden hose gutter cleaning attachment" try it, you'll be impressed!
I was!
leshemeli 1 year ago
Ron47Walker 1 year ago
Love the image in step 3 of the snap-knife kept in the "Band Aid" tin.
Matthew Yang 1 year ago
darknician 1 year ago
RobertP231 1 year ago
tailsnz 1 year ago
JohnW51 1 year ago
All of my gutters except the one built into my patio cover have screens over them. The one on the patio cover is very narrow and hard to clean out. I may try to adapt this idea to that one gutter if I can come up with a quick-release solution.
ghostie222 1 year ago
After 2 knee replacements and getting older, climbing ladders is not a fun thing to do, not to mention the chance of falling.
RandyPerson 1 year ago
At the top, I heated the pipe and wrapped it around a bucket to make a smooth curve to allow the tip to get into the gutter easily. Then, glue on a tee, capping each end with a male hose fitting. I found a nice little hose nozzle at Home Depot, which can be adjusted for a strong jet stream. Not sure the brand, but it's only a couple inches long. Fasten the nozzle to the end of the tee pointing the way you like, and put a standard cap (like from a soaker hose) on the other end. This way, the water shoots right down the gutter, blasting the big stuff out, and washing the small debris down the line. To go the other direction, swap the nozzle and cap.
Yes, you'll want to wear a raincoat. But I can only guess at what comes drifting down from the blower version! Hope this helps.
ncwoods 1 year ago
One thought was to begin at the ROUND portion of your blower and use a PVC (reducer) fitting with an ID slightly smaller then the OD of the blower tube. Heating it with a hair dryer or similar device to allow it to 'slip fit' tightly over the blower tube.
Also like your old metal band-aid box recycle!
dwieland 1 year ago
