Easy to Do Wooden Candle Holder
4,193
174
Introduction: Easy to Do Wooden Candle Holder
This is not only easy and cheap to do, but also quite elegant candle holder for yourself or someone else. Excellent gift idea!
Step 1: What You Will Need?
This is pretty easy project, which doesn't require any professional tools or anything like that to be done.
Basically you will be good with just:
  • Wood glue
  • Wood oil/Varnish (I found oil to look nicer)
  • Drill
  • Hole saw, two sizes (I used 41mm and 67mm)
  • Sanding paper
  • Plywood (any wood will work but I found plywood to look nicer after applying coating)
Step 2: Making Holes
Cut three pieces of plywood with bigger hole saw. Then enlarge hole in one of them by using smaller hole saw. Make sure the candle you are about to put will fit in there.
Step 3: Sanding
Use your sanding parer to make surface smooth from inside and outside.
Step 4: Preparing for Oiling
Wash pieces in water to get rid of dust and let them dry. Then glue pieces together in wanted shape (be creative). Add some pressure in beginning for about 10 minutes and don't forget to let it dry completely for better result.
Step 5: Oiling
Oil it and wait for at least 10 hours. Then wipe the extra with toilet paper and you are basically done at that point!
Step 6: Few More Words...
I'm more than happy with my result, however I must afterwards say that the result could be better if I first oiled and then glued pieces together, not vice versa as I did. Anyways I'm happy to hear what you think about this project and see your results in comment section!
Be the First to Share
    • For the Home Contest
    • Make It Bridge
      Make It Bridge
    • Big and Small Contest
    3 Comments
    Firecaptain29
    Washing plywood often causes it to separate layers, so make sure you use a minimum amount of water. Another comment for the safety issue, use ONLY the little candles that are in the metal tins, especially if you oil the wood. Just something about flame and oil does not see safe. I would recommend using poly rather than oil. And it lasts longer. Be Safe out there !
    matikka96
    matikka96
    Yeah, you are right about the safety! I might add those comments to my instructable. I personally dried it straight away after washing so it forked fine for me.
    tbaltz
    tbaltz
    8 years ago
    I love it
    Very cool idea
    I'm obsessed with Tealight candle holders lol
    That's a cool original way to do it though..it'd be fun to make..I've made a few myself with just 4x4s cedar and crape myrtle branches (took forever to dry)
    And I also made some with old fence boards..YouTube my name and you'll see my awful first video lol
    Cool design though!!
    Take it easy
