Introduction: Easy to Make Leather Dog Made From Just Scrap Material!
If, like me, you are a firm believer in recycling/up-cycling then you may well have some scrap leather laying around at home (mine is from the back of our old sofa) that you can use for this easy but cute project. Who can resist an adorable dog, after all? This project took me less than an hour to make and the pattern can be resized to make dogs and animals of any shape and size.
Step 1: Supplies
You will need:
- Paper for tracing the pattern
- Piece of scrap leather (approximately 16cm squared)
- Craft knife or scissors (strong enough to cut leather)
- Leather hole punch
- Strong sewing needle
- Strong thread
Step 2: Pattern
Print out or copy the pattern. The image shows the pattern on 5mm square paper which fits on to the 16cm squared leather scrap and produces a dog that is approximately 11cm long, 7cm high and 5cm wide.
Cut out the paper template from the PDF attached.
Step 3: Transferring the Pattern
Place the leather face down and position the template to fit within the leather.
Trace around the outline of the template using a pen, ensuring that you mark the lines around the face and the ears.
You will then need to mark the positions of the holes as shown in the template by the dots. I did this by leaving the template on the leather and using a permanent marker to mark the position of the dots which then transferred through to the leather.
Step 4: Cutting the Leather
Cut around the outline on the leather using a craft knife or strong scissors.
Using the leather hole punch tool on the smallest setting, punch the 8 holes out as indicated.
At this stage, I turned the leather over and scored the leather at the base of the tail using a craft knife. This will allow for the tail to stand up when you fold it.
Once done, turn it back to its original position with the leather face down.
Step 5: Start Sewing
Thread approximately 50cm of thread on to your needle (if you can find a thread color to match your leather that would be preferable but don't worry if not. I used contrasting thread to make it stand out in the photos).
Knot the thread securely from hole number 1 to the outer edge, it is important that it is a secure knot to make sure it doesn't come apart.
Once the thread is secure, pass the needle up through hole number 1 from underneath.
Pass the needle down through hole number 2.
Step 6: Continue Sewing
Bring the needle and thread up and over from near the tail and down through hole number 3.
For the next stage, bring the needle and thread up through hole number 4. Then carry it across and down through hole number 5.
Step 7: Finish Sewing
Bring the needle and thread up through hole number 6.
Take the thread over towards the tail and bring the needle and thread up through hole number 7.
Finally, take the needle and thread down through hole number 8.
Step 8: Pull the Thread Tight
Now that the sewing has been completed, start to pull the thread through tightly.
All of the thread holes will be pulled towards the middle.
Once the thread is as tight as it can be, as shown in picture 3, secure the shape by passing the needle and thread through from hole number 1 to hole number 8 several times.
Tie the thread off securely.
Step 9: Finishing Touches
Now the basic shape is complete, your dog requires eyes and a nose.
I have added the eyes using the leather hole punch inserted from behind the ear on both sides. You can choose to draw or paint the eyes on yours, if you wish.
I used permanent marker pen to draw on a triangular nose.
Finally, fold the tail upwards.
I hope you enjoy this fun up-cycling craft!
Leather Challenge
2 People Made This Project!
- atomicpurple made it!
- Marc - FR made it!
5 Comments
1 year ago
So cute
2 years ago
This is so clever! Did you make up the pattern? If so, do you have other leather animal patterns as well? :D
Reply 2 years ago
Hi. Sorry for the delay in replying. I do not have patterns for other animals as yet. I have found some more scraps of leather so may spend some time playing around with the pattern to see what works well.
2 years ago
That is super cute! I've never seen a little leather animal like this before :)
Reply 2 years ago
Thank you for your comment. I love crafting projects - particularly when they involve upcycling and result in adorable animals!
