Introduction: Throw Frogs
Print, cut, glue, fold and play !
This project is a follow up from the following instructable project:
https://www.instructables.com/Origami-Frog-Mini-Games/
Be sure to go check it out to see how to fold the origami frog!
Number of players: 1 to several
Age : 6 to 99 years old
Construction time: 30 minutes
Difficulty of construction: easy
The goal? To make the frog jump into the animal's mouth as quickly as possible, with as few jump attempts as possible!
Multiple players : Count how many tries you need to get the frog in, the one who does it the fastest has won!
Solo : Try to get the frog in as quickly as possible! Repeat as many times as you like!
The possibilities of having fun with folded frogs are endless. Everyone can imagine a way to adapt this game of frogs.
- 1 printer (if you don't have one, you can draw)
- 1 A4 paper with the head of your choice printed
- 1 paper of 270gr (something thicker than simple paper, but not as thick as cardboard to be cut easily)
- 1 scissors
- 1 pencil
- glue
- scotch tape (option to solidify)
Step 1: The Head
- Download the jpg image
- Print in color on an A4 sheet of paper
If you don't have a printer, you can draw an animal with its mouth open on an A4 sheet of paper.
- Cut out the white outline of the head and the location of the mouth.
Step 2: Preparation of the Support Cardboard
- Place the animal's head on the cardboard.
- Draw the location of the mouth, a vertical rectangle under the head, and the circumference of the head.
- Cut the bottom rectangle precisely, the mouth by cutting outside the line, the contour by cutting inside the line.
Step 3: Assembly
- Put glue on the backing paper, at the location of the head.
- Place the head on top, and press.
Step 4: Folding
- Make a fold at the top of the rectangle to fold the paper.
- Then make a second fold 4cm from the first, to reach the head.
Bonus: If the whole thing is not stable enough, you can add tape between the folded backing paper and the head to consolidate it.
Step 5: Have Fun!
Your targets are now ready, all you have to do is send your frogs there.
