Eco-Friendly Thumbtacks From Recycled Old Jewelry, Buttons, Stones, Etc.
3,248
79
Introduction: Eco-Friendly Thumbtacks From Recycled Old Jewelry, Buttons, Stones, Etc.
I do a lot of arts projects with salvaged materials, and these tacks were a simple, fun endeavor. I love how they recycle little pieces and can be customized for whoever wants them since they incorporate a range of materials.
Make-to-Learn Youth Contest
What did you make?
I made a small collection of tacks -- for bulletin boards, walls, posters, etc. -- out of several different materials. I make jewelry as a hobby, and I try to incorporate recycled components whenever possible: parts from old broken jewelry, vintage buttons, sea glass and stones. Thus, I often have many of these materials on hand, so I was able to use some costume earrings, buttons, and stones for the tacks. I only needed the help of my pliers and jewelry glue.
How did you make it?
With this project, I wanted to create an item that kept with the recycled theme but would work for guys and girls of many ages. I had a couple of friends over one evening, and they wanted to help me with some arts projects (I'm preparing for a big show, so my materials are scattered all over the house). One of my friends is a guy, and I wanted to make something he could put to use -- not jewelry -- so I came up with the tacks. Initially, we were making them with decorative vintage pins, but we also added in some single earrings.
Where did you make it?
I made this project at home. I actually taught it to my friends along with several other of my older projects while visiting in my living room. I want to design eco-conscious jewelry and accessories for a career, so this was another accessory I could add to my collection. It is sort of an exercise in making the available resources do and creating, both practices I am always working on in my art classes and hobbies.
What did you learn?
I learned that nearly anything can be turned into something, given a purpose -- even a most simplistic function like being a thumbtack. The first time I made these, I worked primarily with vintage pins. To get a good set of photos, I actually made a second batch of tacks, and this way, I managed to incorporate a wider variety of materials -- buttons, old earrings, stones, etc. I did not have many significant issues along the way -- my biggest one was the tacks sliding off of the decorative components during the drying. I remedied this by propping the tacks on other small objects to level them as the glue set. And, I actually used a thicker glue the second time around, so the tacks set in place sooner. If I were to do this again, I would use other materials -- game pieces, puzzle pieces, beads, and so on -- to further extend the possibilities for this project. I think that's the best part of this project -- making something from seemingly nothing, recycling, and just plain being creative.
Materials list:
-plain metal tacks
-strong glue (I used E600 jewelry glue, but superglue/crazy glue would work as well)
-recyclable materials: single post earrings, old pins, buttons, flat-sided stones, etc.
-pliers
-wire cutters (optional)
Step 1: Prepare Earrings or Pins
If you decided to use old earrings or costume pins for tacks, you'll have to clean up the back of each piece. (This step works for altering old jewelry for many other projects too.)
Use a pair of pliers to grip the earring post where it connects to the back of the earring. Slowly bend the post from side to side and twist it a little bit; the post should pop right off. If it leaves a little stub, you can use the wire cutters to trim off the excess. Just be sure to aim them downward when cutting so the metal doesn't hit your eyes if it flies upward.
For clip-on earrings and pins, do likewise. Grab the earring lever or pin hinge as close to the back of the jewelry piece as possible. Bend it side to side and twist slightly, if need be.
At this point, you should have decorative jewelry components with flat backs.
Step 2: Attach Tacks
Use a plastic toothpick, a popsicle stick, or a disposable chopstick to dab a drop of glue onto the earrings, pins, or buttons. If you use superglue, you can just carefully apply a glue drop with the attached nozzle. Place the tack head into the glue, pressing firmly to set. Allow this to sit tack-point-up for the required drying time (varies by glue, usually around 24 hours in all).
If you have a piece that will not sit flat -- a rounded earring component, for instance -- dab the glue onto the tack, not the decorative piece. Stick the tack into a piece of cardboard to allow it to stay flat in place; press the decorative piece onto the tack in this position. Allow this type of piece to sit tack-point-down, so gravity will hold the materials together while they dry.
And, there you have it. The project is complete. Try using a variety of materials for your own decor -- recycle if you can! Feel free to customize these to your own interests or those of someone you'd like to give them to. They are a simple decoration, but, made right, they are a thoughtful piece of art. Enjoy!
Be the First to Share
    • For the Home Contest
    • Make It Bridge
      Make It Bridge
    • Big and Small Contest
    3 Comments
    claudia.tanseer.9
    claudia.tanseer.9
    8 years ago
    Eco friendly candles...go to the dollar store buy cheap candles and decorate them effortlessly. All of the ideas on ecofriendly things seem to have come from someone who has time (& so e.g. the money!) To sit around thinking of unnecessarily conplicated ways of making handmade crafts....and Im not proposing making handmade kitsch! You are undoubtedly eating out or buying a lot of take out or simply getting paid to think of compliicated ways to produce time consuming (and unaethestically appealing /dimestore quality looking jewelry ) really beautiful paper beads just need good quality glossy mag photos and clear nail polish and an aesthetic sensability. 'Handcrafted' jewelry is much more appealing as much of the higher priced commercially mass produced work . I like the paper that comes from sushi but a $5 fashion mag with the worlds best photographers provides enough paper to make at least 10x as many pieces. The metal junk you produce wastes too much time and energy to copy cheap costume jewelry. Claudia Tanseer
    claudia.tanseer.9
    claudia.tanseer.9
    8 years ago
    If being eco friendly is the goal the amount of time energy and the cost of sushi seems to negate the idea. Beautiful paper beads can be made from humble disgardedmagazine and merely coated with very cheap clear nail polish. The ideas presented here would seem to attract people who want to appear techno savvy but who dont realize that the goal is beautiful earrings that can be created from any discarded glossy magazine ...buying varnish is ridiculous. $1 clear nail polishlooks the same is applied carefully
    That's a great idea! I know of a craft reuse store that always has bunches of unmatched earrings too, this would be perfect for that!
