Introduction: Eco-friendly Food Film
In a world increasingly aware of the environmental impact of consumer products, there is a growing demand for sustainable alternatives to single-use plastics. Traditional plastic films, used to wrap and preserve food, contribute significantly to plastic pollution. This biodegradable elastic film was born from the need to reduce the use of plastic and provide an ecological and reusable solution for food preservation. Biodegradable film is used in a similar way to traditional plastic films. It is used to wrap food, cover bowls and plates, maintain food freshness and prevent contamination from dust and moisture.
This film is inspired by nature and traditional food preservation practices. The use of beeswax and natural oils to seal and protect foods dates back centuries. The antimicrobial properties of turmeric and grapefruit seed extract add a modern, scientifically supported twist to these ancient practices. Inspiration also comes from circular economy practices, where the goal is to create products that have a life cycle closed, minimizing waste and maximizing reuse and recycling. Biodegradable film embodies these principles, offering a practical solution that can be easily integrated into everyday life.
Agar - Agar 4 tbsp
Vegetable glycerin 2 tablespoons
White vinegar 1 tsp
Water 2 cups
Turmeric for its athymiocrobial properties
Baking paper
Step 1:
1 Mix the Agar Agar with water in a saucepan until you obtain a smooth solution.
Add the vegetable glycerin and white vinegar to the mixture and mix well.
For antimicrobial properties, add a pinch of turmeric and mix.
Step 2:
Heat the mixture over medium heat, stirring constantly until it thickens and reaches a gel-like consistency.
Step 3:
Line a baking tray with baking paper.
Arrange the organic cotton fabric squares on the baking sheet.
Step 4:
Use a pastry brush to apply the mixture evenly
Step 5:
Place the tray in the preheated oven at 60-70°C for 15-20 minutes or until the mixture is completely dry. You can also let the squares dry at room temperature for several hours or overnight.
