Introduction: Edison Lamp Dimmer 230V Arduino IRDA Remote Control
In this instructable I show You how to make 230V dimmer based on Arduino.
I use remote controller of my Samsung TV, but it's not necesary. Take a look at YouTube video embedded above.
In nex steps I describe shortly how to build a circuit.
Step 1: You Will Need...
Parts to buy:
- MOC 3021 optocoupler
- BT136 triac
- Resistors:
1 x 360 ohm 1/4W
1 x 330 ohm 1/4W
1 x 33K ohm 1/4W
2 x 68K ohm 2W - AC/DC 5V power supply
- Arduino ;)
Arduino code:
https://github.com/oscdeveloper/arduinoLightDimmer
Step 2: Circuit Sketches
We can split this circuit in three parts:
- Ardunio as a microcontroller.
Keeps all instructions how to behave. - Zero cross detection module based on PC814 or EL814.
Tells Arduino when it should trigger the Triac BT136. - 230V trigger based on Triac BT136 and optocoupler MOC3021 to dim a bulb.
All images You have above of this step.
More info You can find below. It's the best description of I've found about 230V and Arduino dimming.
https://www.instructables.com/id/Arduino-controlled-light-dimmer-The-circuit/
