Introduction: Eduino Eduardo
Eduino Eduardo is an improved DIY Arduino UNO R3 compatible development board. I have designed it to teach children soldering, electronics and programming.
If you want to know more about my work: There is an arcticle from our local newspaper
Features
USB B connector
Power supply socket, 6-12 V input voltage
Switching of the supply voltage via two Texas Instruments power-distribution switches (TPS2041 / TPS2051)
Current limitation for both supply voltages (USB / VIn)
Overcurrent indicator via two red LEDs
PIC 16F1455 as USB microcontroller with official sublicense of USB VID/PID (0x04D8/0xF015) from Microchip
Reverse polarity protection up to 30V for VIn
Compatible with Arduino Uno R3
Step 1: Solder U2: TPS 2041B
Check orientation!
The gray line on the IC has to be positioned upwards, at the little white circle inside of the red enclosed area.
Step 2: Solder U7: TPS2051B
Check orientation!
Step 3: Solder U1: AMS 1117 5.0
Step 4: Solder U6: AMS 1117 3.3
Step 5: Solder R1, R3, R8: Resistor 10 KOhm
Color code:brown, black, black, brown, brown
Step 6: Solder R2, R4, R5, R6, R7, R9, R10, R11: Resistor 1 KOhm
Color code: brown, black, black, red, brown
Step 7: Solder U5: IC Socket 28 Pins
Check orientation!
The notch on the socket has to match the notch as stenciled on the board.
Step 8: Solder U4: IC Socket 14 Pins
Check orientation!
Step 9: Solder Power: Female Header 8 Pin
Step 10: Solder Analog In: Female Header 6 Pin
Step 11: Solder Digital: Female Header 8 Pin
Step 12: Solder : Female Header 10 Pin
Step 13: Solder C1, C3, C5, C7, C8, C10, C11, C12: Capacitor 100 NF
Step 14: Solder LED4 and LED5: LED 3mm Red
Check polarity !
The long leg has to be positioned on the left side (+ sign on the board )
Step 15: Solder LED1 and LED2: LED 3mm Yellow
Check polarity !
Step 16: Solder LED3: LED 3mm Green
Check polarity !
Step 17: Solder D3: Diode 1N4148
Check polarity !
The black marking has to be positioned on the left side
Step 18: Solder D2: Diode 1N5819
Check polarity !
The gray marking has to be positioned upwards.
Step 19: Solder D1: Z-Diode ZPD 5.1
Check polarity !
Step 20: Solder C4 and C6: Electrolytic Capacitor 47 UF
Check polarity !
The long leg has to be positioned downwards (+sign on the board)
Step 21: Solder C2 and C9: Electrolytic Capacitor 10 UF
Check polarity !
The long leg has to be positioned on the left side at C2 (+sign on the board) and downwards at C9 (+sign on the board)
Step 22: Solder L1, L2: Ferrite Bead
Step 23: Solder: Resonator 16Mhz
Step 24: Solder ICSP: Header Male 2x3
Step 25: Solder X1: DC Power Jack
Step 26: Solder X2: USB Type B Connector
Step 27: Short Circuit Check
Check the bottom side for possible soldering short circuits
Step 28: Power Supply Check
Connect the board with a PC or a USB charger via a USB-B cable.
The green LED should light up now.
Step 29: Short Circuit Test
Connect GND and +5V with a jumper wire cable
Then connect the board with a PC or a USB charger via a USB-B cable. The red LED on top should light up now (Overcurrent indicator)
Step 30: Mount PIC 16F1455
Check orientation !
The IC has to be mounted carefully, with the notch in the IC matching the notch in the socket.
Step 31: Mount ATMEGA328P-PU
Check orientation !
Step 32: Boards Availability
If anyone would like a board, it is already shared on PCBWay:
https://www.pcbway.com/project/shareproject/Eduino_Eduardo.html
