Introduction: Eeepc Bicycle Mount
Shock proof Eeepc cable mount on bicycle. As I am an addicted openstreetmapper, I was curious if I could add navigation and mapping system to my car. I could. But that was too easy and could not give me access to all the small footpaths and trackroads around. I had to attach my navigation tool (eeepc 701 with webcam and custom added RAM 2GB, but only 4GB SSD) to my bicycle. So this is an instructable about how to combine a bicycle and a notebook. I went through a few trial and error setbacks, almost dropped my notebook on the road while riding, but thankfully came to my goal. And I want to share it with you.
All pictures are of finished product, but it is not so complicated, or with other words - Im too lazy to interfere my work to take pictures :)
Step 1: What You Need
- a bicycle
- a notebook, preferably subnotebook, definitely not the 15inch widescreen one
- plywood 5 layers, 6mm thick, two times 16X22cm=, two areas of your notebook
- 17 pieces bolts with 7mm nuts, 10mm long, 4mm thick, conical head
- 9 screws for plywood, same length or few mm extra as plywood thickness. I had 11mm long, 8mm measuring without head
- 4 long screws for wood, some 2cm long
- 1 long nail, some 10cm long and 4mm thick
- 2 bricks of wood, approximately from 2 to 4 cm wide, some 5 to 8cm long and at least 4cm high. But this depends on your bike. My bricks were 3cm wide, 7.3cm long and 4.5cm high
- wire rope 4mm thick ~1m (for 1kg eeepc)
- 4 metal parts 1-2mm thick, 12mm wide and 14cm long - almost as long as your notebook. I got those from an old metal constructor set from my childhood. It has holes every 12mm.
- another same type metal part to hold your construction to your bike
- some aluminum sheet, not more than 10x10cm. I got mine from an old CD-ROM drive.
- little bit of rubber, sponge or other soft but firm material 1mm thin. I didn't need it, as my old CD-ROM had it glued inside already
- 4 rubber rings, fasteners 1mmX2mm thick and approximately 4cm diameter. Any rubber would do.
- plywood saw
- metal saw
- sandpaper
- power screwdriver, also to be used for drilling holes
- drill bit for wood 4mm
- drill bit for metal 4mm. Quality should depend on your metal hardness.
- metal file, to shorten too long screws and to work on edges
- hammer, necessary even if working with electronics!
- vice, to hold your work
- pliers
- ruler, a bit longer than width of your notebook
- pencil
Time to work on this, one afternoon, probably few hours. Not sure as i spent a week with some trial and error returning to previous steps.
Step 2: Lower Part, the Stiff One
This was initially the only part until I realized this is a no-go. It was only good for roller skate good ways without even speed bumps. And that wasn't my intention. First I traced the outline of my eeepc on the plywood and sawed it out, worked around the edges with the file. Not notebook, but plywood edges! This part can be a bit smaller than your notebook, as it is hard to make so much room on your bike. Then I sawed two wood bricks, to screw under this plywood shelf in a way to hold it on the forwards extending pipe and not move sideways. Many bicycles has just one pipe coming vertically and then another one going to both sides. My bicycle has another one in between those two, extending the horizontal pipe more forward. Basically this shelf rests on the horizontal pipe and cannot move forward because the bricks rest against the horizontal pipe, cannot move sideways cause the bricks are on both sides of the extender pipe. To not let the shelf move down, you need to make a horizontal hole through both bricks just above the extender pipe. This hole will have the long nail through when the construction will be mounted. Be aware, that this hole is the only means of adjusting the forward angle of the shelf and later the notebook to sit comfortably to your eyes. That depends on how much you can open your notebook. The first eeepc can open up as wide as some 160 degrees, that will be how it will sit on the higher shelf. Another thing to note, the screen is not very sunlight friendly, but again, you will not look in it all the time, only occasionally.
The last thing to this step is to add the fifth metal part. It needs to be so long, to be bent around your extender pipe and come to the nail and have holes at ends for the nail to go through. So it is bent like a U and has holes. When you will attach your construction to your bike - put the shelf on your bike, so the bricks slide around the extender pipe, slide the U metal thingy from downside in between the extender pipe and wood bricks and slide the nail inside the wood bricks holes, and U thingy holes, so the nail sits over the extender pipe. Now the construction can't move anywhere and is stiffly attached to your bike. If you have your bricks longer down, you could even manage without the metal U thing, but two nails instead. Be sure to drill your bricks hole for the nail, so the nail rests against the vertical pipe, not allowing the construction to slide backwards.
Step 3: Upper Part, the Notebook Shelf
Make another plywood shelf, same size as your notebook. Now the size matters. First take some aluminum. I got mine from an old CD-ROM, it even had some sponge like amortization stuff very well glued to it. Saw two pieces 2cm wide and some 6cm long. You can make them wider, or even make just one, but depending on your notebook touch pad or some buttons placement try not to cover any essential stuff. Also take a look at where the ventilation exhausts are, try not to cover them. Place your notebook on the shelf and put the two aluminum pieces vertically in front and draw two horizontal lines, where you need them to be bent. Then squeeze them in vice, so the line is aligned with vice edge. and carefully hammer - bend them to 90 degrees. After two attempts you should have them like flat sided U shape. The second attempt would go better with pliers, but they have to be with flat and long enough edge. And you have to hold them very tight when you hammer. And rest your pliers at the ends on something hard, the vice for example. It is enough with just one hole in each part. One short screw will hold it. Remember to file the screw flat to the plywood level, if it comes a bit out of it.
Now the back rest, the most forward one. It is simply an aluminum holder for your notebook not to slide forward, especially when you brake. It holds to the upper shelf by three screws, all were a few millimeters longer than needed, so I filed them to same level as plywood. But only after I saw some scratches on my notebooks battery. The black part on it is again the sponge like stuff. If you haven't and old CD-ROM drive, then you need to glue some sponge or rubber there. In the middle there is a metal bolt with a nut, which holds a little hook, which in turn holds the rubber rings two in my case for each upper screen corners, I just tied them together to make long enough.. This is necessary, my trial an error testing phase showed, that the notebook can slide-jump-rotate out and decide to move in another direction than you. But I was lucky somehow catching it on the way down almost at pedal level. Not sure how long the rubber rings will hold, but I still have enough of them from old times. They were used to hold together a lot of bus tickets at bus stations.
The third thing for the upper shelf is two metal L shaped things on both sides, to not let the notebook move sideways. I screwed them with two screws each, but it should be sure enough with one screw. I had them with some holes, so I didn't need to drill. I bent a little end of them inwards, so they better hold the notebook. This is a weak part of my design, as it is a bit hard to get the notebook in and out. And they make a little rattle noise when harsh road conditions encountered. That could be remedied by gluing some rubber to them. Will try that at some time.
Step 4: Cable Mount, Vibration Absorber
This took me some thinking. Springs were considered. But I didn't have any. And mounting them would be not fun. Pneumatic or hydraulic struts... no, that's overkill from all points of view. I went to my towns hardware store. Not much there. And I saw a wire rope. A design idea came to me, bought 2 meters. Later used only one meter. At first it looked a hard work to attach the two plywood shelves together with this wire rope. This is how I did it.
I lined up two holed metal parts in same direction as bike moves normally, and spaced them 3.5cm from edges of shelves and 15cm from each other. I drilled 4mm holes in plywood all along them. You only need 2 holes at each end2,5cm apart. that makes 4 metal parts (instead you can use 8 pieces small, short ones with only 2 holes each. I bought such, but made my design with long ones anyway) times 2 ends times 2 holes each end and at the end makes 8 holes upper shelf and 8 holes lower shelf.
Now screw the bolts and metal parts together, just to hold it together. All 16 bolts have to go in. Hold one metal part rised and slide the wire rope under it, so it extends on the inside a few cm. Now screw the first two bolts firmly, so the wire is tight. This is the only reason, that will hold the upper shelf right on top of the lower shelf. That's why screws wont do it, you need bolts here. Make sure the wire is 90 degrees to the metal part.
Now comes a bit tricky holding it all where you want moment. Position the upper part over the lower and slide the wire rope same way, but other end from outside to inside over its metal part. This time slide almost all wire through and on the other side over the other metal thing (over metal, under upper shelf, between two bolts). Now connect the other side of both shelves with the rope going from out to inside under the third metal thing, just over the lower shelf, between two bolts. Now the construction gets a bit easier to hold. Be sure to twist the wire, so it rests as freely as possible. The only force acting upon it is the one because it is bent. Next wire it diagonally to the same, lower shelves other corner. Let it go through two bolts again, so it comes out on the right side. Now bend it and connect the upper shelve by wiring through its two screws from right side to inside. Continue the wiring straight out to the left side. The last place to connect, is the lower shelves left, closest to you corner. Do it! Connect it!
Now you have all the necessary wire rope where it should be, with only 2 bolts tight at one end. Adjust the length of the rope by pushing and pulling where necessary, to make both shelves aligned on top. Tighten the bolts in same order as the wire goes from the first two tight bolts. When all 16 bolts tight, you should have your construction as it will be. You shouldn't care about the metal parts bending. The only thing, that matters is that the wire is tightly screwed to the shelves.
I ended up with my shelves spaced apart some 6.5cm
Step 5: Ready, Mount, Go!
I am waiting for more free time to test my constructable extensively. Now enjoy the last pictures and give me some ideas for improvements.
11 Comments
11 years ago on Introduction
Also, as a matter of curiosity, where would you go that you would be exploring city streets, in which you would be travelling up to 20 hours? With typical bicycle touring, that would involve an overnight, and camping on the sidewalk is just not advisable....
Reply 11 years ago on Introduction
You know, there are also countryside in some far far away place. The city is not from one edge of the world to the other :)
uldics
Very nice project. I was wondering if a lot of people in the Open Street Map community make use of your product? Also do you have any power problems for your laptop?. I asked because I have been putting together a setup to allow me to charge a laptop or a laptop battery or maybe even power up
a laptop while biking. I found a perfect bike bottle dynamo that may make that possible. I am testing it out now. Do you see any need for that in the Open Street Map Community?. The setup is not very difficult. Let me know if you
have any interest in this.
I doubt that, cause now almost every phone has a GPS, so everybody just uses a smartphone for same purpose. But powering a laptop sounds interesting. The problems I could see with that is regulating the voltage and generating enough power, while cycling slowly. I am not sure if it would not get the laptop switching chrge/no charge all the time.
OK, I guess that now people use GPS and it is easier to charge on a bike. No
more need for laptop. I have friends that go on very bike trips in the out-of-the
-way places and they need to chrage laptop while biking. I have found a way
to help them. As far as voltage regulating, it's not a problem; you can buy a
voltage regulator (small little circuit unit) or you can use a charge controller.
As far as having enough power, you are kinda right, I was almost given up
looking for a powerfull enough bike wheel dynamo but I found this dynamo
made in China and a Hong Kong product. It is a bottle dynamo called
Nicco MT-032. The manual does say anything about this dynamo but I
measure the voltage and it can go as high as 24V AC (without load) and the
current can be as much as 2A. This is with biking speed around 15km/hour
to 20km/hour. Most dynamo rated at 6v 3W or 12V 6W and they are useless.
But the Nicco is good enough to charge a laptop battery in about the same
rate that you would charge using AC power. I am in the process of testing it
out.
I though that maybe you are using the note book on your bike for some other
reasons and since you mount a note book on your bike I thought you might need to charge it as well.
Just what my fellow cyclists need: one more fekkin excuse to not look where they are going!
Good intention, I suppose, but if a bunch of typical people do this (i.e. not good multitaskers), they are going to be distracted enough to hit solid objects in short order, damaging their computers, and skulls!
Instructables aren't for "typical people", and that's generalising anyway.
12 years ago on Introduction
Nice idea, but completely CRAZY. I'm afraid I value my notebook too much to attempt that.
Smart cable isolator! Does it work well?
Hope you don't crash though.
Reply 12 years ago on Introduction
Yes, it works pretty good. In rather fast and bumpy rides it swings pretty much, but thats what its purpose is - to lengthen the notebooks movements and slow it down.
If I should rate my constructions effectiveness, then I would say my speed at bumpy places have to be reduced only 10-20% in relation to riding with clean bike, no notebook attached. My first prototype, without the wire, just with rubber spacers, was like 90-95% necessary speed reduction at rough terrain.
Useful, I have an interest in mounting a camera on a moped / scooter. L
