Introduction: Ehow Outdoor and Indoor DTV Antennas.
Under reconstruction.....
Somehow the text for this frame was lost. Anyway I wanted to make my own version of their antenna. Thinking it would be like the (second) picture was a real mistake. NormallyThe third picture I think is the type of antenna the original antenna was intended to duplicate. I would not include such a picture except for clarity. Also included are other pictures of foild antennas we have made. The ehow antenna was made with coat hangers and wood. We wanted somethhing a little safer for indoor use.
Note: I went to look for the original article so I could quote it, but could not find it.:In any case it came from ehow.com. It was similar to this article: http://www.ehow.com/how_7788726_build-vhf-tv-omni-antenna.html
Step 1: What's Needed.
14-inch long non-coated brazing rods (16)
Metal coat hangers (4)
300 ohm twin lead flat antenna wire 20 inches long
15 by 9 inch cooling racks (4)
Oil based outdoor wood sealer
2 by 3 by 21 inch piece of wood (2)
1 by 2 by 18 inch piece of wood (2)
No. 10 wood screws one inch long (20)
No. 10 wood screws two inches long (8)
No. 10 flat washers (20)
75-ohm VHF/UHF transformer balun
Pliers with wire cutter
Sandpaper
Squeeze tube of outdoor weather caulking
Paint brush
Antenna mast or rotor
Our version:
Glue.
Thick poster board
Regular poster board
Rolls of aluminium foil.
Tape.
Styrofoam blocks.
Step 2: Step 1.
Paint with a clean brush all surfaces of the wood with an oil-based wood sealer. Let the wood dry fully overnight.
Note: We are going to use double thick poster board.
Cut the ten pieces of poster board to size. (4 - 2 x 18 and 6 -3 x 21) and can be done with one poster board.
No painting is required, but you will need to glue each of the two/three piece sets together for four separate units. Let dry.
We had some leftover partially unused poster board, so I made 2 extra 2 x 18 sections so all the boards would be the same thickness as the longer units.
Step 3: Step 2.
Cut the twisted hanging section of the coat hangers using the wire cutting section of your pliers. Straighten the remaining piece of each hanger. Using the pliers, bend one end of each of the two straight wires to form a small "U" to fit around the screw. Sand off the coating on the "U" section.
Note: We will be using four twenty one inch strips of folded aluminium foil. Fold them lengthwise till you get thin strips. Take an ohm meter or a continuity tester and make sure the foil conducts electricity. You will have to use something else if it does not.
https://www.instructables.com/id/Yet-another-continuity-tester/
Step 4: Step 3.
Note: Sixteen more fourteen inch foil strips that you will need to fold as in the last step.fold each strip into a vee pattern with a three width between the tines.
Step 5: Step 4.
Note: we will be using a double thick poster board. Also shown are the shorter sections. Notice the difference on the sections I cut with scissors versus using a razor blade.
Step 6: Step 5.
Note: In our version you will not need to do this. So take a break for a bit and then continue on.
Step 7: Step 6.
Note: we will tape down the "V"-shaped rod pointing straight out from each of the points we have marked. we will tape down the tines instead of using screws at the focal point.
Idea: If I had to do it over again, i would just cut out the pieces form a foil tine and just fold them over. That is sturdier, quickerm and therfore easier.
Step 8: Step 7.
Cross the two straight wires over to the opposite side of the wood. Slide the wires under the washers of the second and third set of screws from the top. Slide a "V"-shaped rod under each washer. Tighten the screws, keeping the open end of the "V"-shaped rod facing straight out from the wood.
Note: be sure not to let the two foil sections touch where they cross. We liberally used tapeto make sure there would be no contact.
Step 9: Step 9.
Note we have already used the tape to accomplish this. You could use an ohm meter to make sure their is no connection.
Step 10: Step 10.
Note: tape down the balun. Balun should not be touching the foil.
Step 11: Step 11.
Note: Attach the wire and tape down.
Step 12: Step 12.
Turn the antenna over and screw two 15- by 9-inch cooling racks (reflectors) to the wood. One rack will line up with the top two bow ties and the other with the bottom two bow ties. Do the same with the other antenna section using the last two cooling racks.
Note: Cut 4 pieces of poster board and 4 pieces of foil nine by fifteen inches. If you can not get foil the right size, cut additional pieces to fit. Glue the foil to the poster board with the shiny side away from the poster board. Let dry!! Optional: Cut long strips from the unit so that it looks like a grill. Glue the spacers to the back of the three by twenty one inch units. Let dry. Glue the units you have made to the spacers arranged as above.
Could not find any 9 x 15 cooling racks. but the ones from the dollar store probably would have worked good enough.
Step 13: Step 0d.
Note: We will lay ours face down to make glueing the cross members easier and then set for one inch apart.
Step 14: Step 14.
Note: Glue the four pieces into place. Let dry. (To be honest, I used some wood screws to make it a bit more stable.)
Step 15: Step 15.
Note: tape the flat wire to the same corresponding part of the foil on the other half of the antenna. At the making of the this instructable with did not have any 300 ohm wire yet.
Step 16: Step 16.
Squeeze some caulking over the screw connections to protect them from the weather. Attach the antenna to the mast or rotor on the center of the cross supports using screws. Connect the cable from the TV and you are finished.
Note: Just connect the cable from the tv. (The microsphone stand ends up getting another use. Need to make a second on for the antenna.)
Step 17: Addendum:
Optional variation of the antenna. Actually that is what I thought the antenna might look like before reading though all the steps completely.
