Introduction: Elastic Band Flinging Helicopter
This is a toy I used to play with as a kid. It was always a cheap plastic one that I bought, but figured it would be easy enough to make, so gave it a go.
Obviously you can play with the design depending on what materials you have lying around, but this should give you a rough idea of what direction to go...
Date Made: June 2013
Approx Cost: £0 (recycled materials)
Approx Time: 0.5 to 1 hrs
Difficulty: Easy
Step 1: What You Need
Materials you need are:
*some fairly stiff plastic (I used the packaging from a roller blind)
*a big thick elastic band (I used one about 200mm long)
*a picture hook
*a piece of dowel (I used the adjuster from a venetian blind, which already had the hook screwed in the end)
Tools you need are:
*some extra strong glue
*a hacksaw to cut the wood (I used a dremel)
*scissors or knife to cut the plastic
*pliers
Step 2: Make Propellers
Cut two pieces of plastic approx 30mm x 150mm.
Next fold them on an angle about 30mm from one end as per the photo.
Make them both match.
Step 3: Make Main Body
For the main body cut a piece of the dowel approx 200mm long.
Cut a slot in one end almost the same length as the fold line.
In the other end cut a small hook along the same plane as the slot, that way the propellers wont catch on the body when released. Make the hook small, but check the elastic band will latch on to it. If this is too big, it will catch on launch and misfire.
Step 4: Form Helicopter
Glue the two propellers together, but make sure that you don't glue too close to the fold line.
Next glue the propeller in to the slot on the dowel. Make sure the glue is strong and can take some good force - if it doesn't, you will hurt yourself later!
Only fix the propellers to the body below the fold, so that when releases they can bend at the fold line.
Trim the propeller so that it tapers in to the width of the body
Finally fold the propellers along the fold lines.
Step 5: Form Handle
Cut the dowel to approx 200mm in length - long enough to hold.
Screw the picture hook in to the end of the dowel.
Fix the elastic band to the hook. I did this by putting the elastic band through and then closing the hook with pliers. You could alternatively do it by means of a knot, glue, staple or you could drill a hole through the dowel.
Step 6: Launch
Hold the dowel bar in one hand, and the helicopter in the other. Holding on to the end of propellers together will ensure that they don't restrict the flight on the way up, then hopefully they will spring back on the way down.
Clip the open hook of the body in to the elastic band, pull back and release!
The helicopter should fly in to the air like a rocket, and then spin down like a helicopter!
You may need to play with the weightings etc depending on the materials you use, so you could put blu-tak on the end to make the front heavier etc.
WARNING: be careful of your hands and face! If this misfires and it hits your hand/face, it really hurts (I know from experience!), and if it hits you in the eyes it could do some real damage. So best to wear gloves/glasses whilst testing! Also make sure that the picture hook is completely closed, so that the elastic band doesn't sneak out and hit you in the face!
Here is a video, you cant really see it whilst in the sky, but you can see it spin to the ground.
Step 7: 3D Model
I have created a 3d model of the handle and the main body, so alternatively this could be printed. I did this on tinkercad, and can be found by searching for "helicopter flinger", or below.
Please note that this 3d model should really be classed as a prototype as I do not have access to a 3d printer so cannot print and check that this is strong enough for the purpose intended. I presume different materials would behave differently anyway.
Second Prize in the
Toy Contest
Grand Prize in the
Launch It! Contest
Great Outdoors Contest
13 Comments
7 years ago
not bad
8 years ago on Introduction
cool
8 years ago
very good
10 years ago on Introduction
I have updated the tinkercad model to round off all the ends, as this should reduce the chance of anything 'catching' on launch...
Congrats on winning the contest. I have a Syma 107/107g helicopter and it is a lot of fun!
What a fun toy!
Thanks, wasn't expecting to win! Some awesome instructables in that contest...
I was thinking about making one of these a few weeks ago, but with an LED at the hook end so it lights up the ground where it falls (and looks cooler). Nice instructable!
Nice idea. Look cool and makes it more visible to others.
Also good because people probably won't step on it. Although, they might rush to get it next and stand on it like that. Happened to my flying stuff many times...(especially cats and ornithopters)
Good job!!! awesome!
10 years ago
nothing like the dangerous weapons, I mean toys of our youth.
Yeah, I wasn't sure if I should put more warnings on. Everything seems dangerous to me now, but I survived my childhood so it couldn't of been that hazardous!!!
