Introduction: Elastic Grid Organizers
The good people at Cocoon have a great product with GRID-IT™ organizers. Sometimes their designs don’t match my needs or budget. It turns out that it’s easy and fun to make your own. The basic idea is to weave elastic on a backer. Here’s how I do it.
Step 1: Materials and Tools
You will need a backer, adhesive, scissors, and elastic.
Who knew elastic could be so complicated? I use three types of elastic webbing in my projects. Plain elastic comes in lots of sizes and colors. I use it to stretch out (pun intended) my gripper elastic and make pretty patterns.
Silicon grip elastic comes in lots of colors too. It’s lightweight and works for small projects.
Heavy duty grip elastic provides the core of strength. The grip acts to hold down items and to keep the matrix in place. I ended up alternating (up or down) the grip side of the elastic to provide support to the other ribbons on my web.
Hot glue worked great for me. It’s hot! It sticks! Don’t touch it.
Step 2: Prepare Your Backer
I used scrap pieces of thin plywood for my backers, and I found it helpful to draw registration marks on the back side, and to stick a thin piece of foam on the front side to cushion the grid. Metal or acrylic backers would probably work too. If you have specific items in mind for your grid, just make sure your backer is the right size.
Step 3: Glue Some Elastic
To start, set some elastic on one end of your board. What I learned here is that you should not pull your elastic very tight. It needs stretch to be able hold items, otherwise the grid will pull all the elastic too tight to the backer.
Step 4: Weave Elastic
I start by gluing all my horizontal pieces, then cut and weave the vertical strips into the grid. It’s fun to play with colors and even different weaving patterns.
Step 5: Populate the Grid
Add your items. It's mostly tools for me.
