Introduction: Electric Chair
An electric chair AND LEDs, oh my. However, this instructable is more about a demonstration on the coefficient of thermal expansion between different materials. Before I lose your attention, did I say that there was going to be molten glass, LEDs, AND an electric chair ( in this case, a small chair like object with current running through it).
Step 1: Making a Simple Circuit With Copper Wire
I used copper wire that was twisted and crimped to make part of the simple circuit. Since this will be encased in 2000 degree molten glass, I am pretty positive that solder won't hold up too well.
I am just guessing, but things like IC chips and mosfets won't hold up to 2000 degrees either.
I did not want the copper too thick because there is a good chance the glass will crack. This will be explained later.
Step 2: Time for the Hot Glass
The video clip is part of another method that I had tried.
Step 3: Quick Side Note
Now, every material like copper, iron, glass(depending on the formula), etc, have different coefficents. If their coefficients are close enough, then they may be compatible. If their coefficients are too far apart, they will most likely be incompatible.
There are probably hundreds of different glass formulas and most are incompatible with each other.
Normally, just tossing random materials in hot glass will cause the glass to crack when it cools.
The copper wire that I am using is just compatible enough with the base glass I am using that there is not a problem with cracking.
That being said, a large chunk of copper or very thick wire may crack the glass eventually.
Step 4: Finishing the Simple Circuit
Step 5: A Few Last Photos
This page has a few photos and video of another copper circuit encased in glass. This has got a little art nouveau feel to it.
