Introduction: Electric Egg Whisker
Have you ever tiredly whisked eggs and wished it went faster? I got the solution. With a press of a button you will have your eggs whisked in seconds. Have fun!
Cardboard, motor, small whisk, small needle size of motor tip, Velcro, switch, 2 AA batteries, 2 AA battery holder, and hot glue gun.
Step 1: Make the Circuit
This is fairly easy to make. To start, connect the switch, battery, and motor together. Turn it on and see if it moves. If it does not move than make sure your circuit is correct.
Step 2: Make the Base
Glue 4 1 inch by 2.5 inch pieces of cardboard together to make a box. Make a hole for the switch. Put the battery in the box and Velcro it down. Place the switch inside the hole you made. Glue the motor at the top of the box, but make sure the tip of it it outside of the box. Take your whisk and solder a tiny hole the size of the motor tip in the bottom of the whisk. Stick the motor tip in the hole you made. Place a layer of hot glue on the motor tip and whisk to keep them in place. Turn the machine on. The whisk should start spinning.
Have fun not whisking ever again! Please like!
