Introduction: Electric Motor DIY
This video explains how to make an electric motor using a cork.
Step 1: Electric Motor DIY
Here it is explained how to make an Electric Motor using a Cork.
We need the following material:
- Cork
- copper wire
-small copper axis
- 2 small pieces of copper to make the electric contacts
- small support of wood
- 2 "L" of lateral support.
We need the following tools:
- drill
-knife or cutter
-scissor
- saw.
Step 2: Actions on the Cork
- a) Find the center of the cork and make a hole following the vertical axis.
The hole has to have a diameter about 1 or 2mm. It depends from the diameter of your shaft. We have used a rigid copper wire as shaft of about 2mm of diameter. The hole diameter has to be bit less than the diameter of the used shaft.
- b) Insert the shaft into the cork
You can try to insert the shaft without hole, but it should be a patient action and you should follow the center of the cork.
Shaft: The shaft has to be diamagnetic otherwise it will be attracted by the magnet. We have used a rigid copper wire.
-c) Draw 4 lines for the coils channels on the cork surface
-d) Carve the lines on the cork using a cutter or knife making the coils channels
Step 3: Wind Up the Copper Wire Making 2 Coils
Wind up the copper wire making 2 Coils.
HOW TO WIND UP THE COPPER WIRE IN THE CORK CHANNELS:
it is very important to not make mistake executing this step. So follow the instructions in details:
a) label or identify the up of the cork and during this step let it in the same direction.
b) label or identify the terminal point of the copper wire as S1
c) wind up the copper wire in clockwise direction following one channel and passing into the diameter channel (up and down of the cork) and then make a coil of 40/50 turns.
d) cut the copper wire when you arrive beside the S1 and identify this wire terminal point with S2.
e) do the same actions (b to d) for the second coil, passing into the orthogonal channel of the first coil, identifying the terminals points of the copper wire as S3 and S4.
Step 4: Make the Motor Support
- Make the base
We have used a piece of wood
- Make the lateral support for the motor
For both of the L:
- make an hole of 2 mm (or bit larger than the shaft diameter) on the lateral side of the L. This hole is for the motor shaft.
- make 2 holes on the base of the L for the screws.
-Fix one L on the base using 2 screws.
The second L will be fixed later.
We have used 2 L of aluminum.
