Introduction: Electric Pickle Lamp
Plug a pickle into a 120V AC outlet and watch in glow.
Materials:
The sodium in the pickle burns yellow. Yellow street lights are sodium-vapor lamps.
Video 1:
Video 2
Materials:
- Pickle
- AC power cord
- Thick copper wire
- Cut and strip the power cord. Wrap together the neutral and ground wires. Cut the live wire about 6 inches shorter than the neutral/ground. This will reduce accidental shorts.
- Cut 2 pieces of thick copper wire, about 3 inches long I used a piece pulled from a household electrical wire (the kind that go in the wall)
- Stick the wires in the pickle
- Connect the AC power cord to the copper wires. I've used a cheap set of jumper cables between the power cord and the pickle.
- Plug the the power cord into an electrical outlet.
- Wait for the pickle to glow. It took about 10 seconds to get going.
- Unplug everything.
- Be careful -- safety eighth!
Video 1:
Video 2
Electronics Tips and Tricks
22 Comments
10 years ago on Introduction
This is a really cool project. On an unrelated note, I just thought of an awesome band name.
Reply 3 years ago
What was it?
It will work on 110V? I thought it needed more than that.
Reply 5 years ago
HEY
Yup - This is from a regular 110V household outlet (North America) - on a 15amp fuse.
On 240 volts??
It might blow up with 240. Safety glasses, yo.
Its ok if you get your pickles from the UK :)
I don't see why not -- careful though. My only 240V circuit is behind the dryer. Did not work with a 12V car battery.
Cool...
5 years ago
I am doing it for my science fair project. HAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA
5 years ago
Works fine on 240v, 50cyc. in New Zealand.
7 years ago
Does it work on a cucumber or a tomato?
nice lamp.
I wouldn't eat it. There's likely to be metal from the wires /nails dissolved in it, and possibly even a bit of metalic sodium (toxic)
One of those chem ironies that sodium ions in salt is a necessity for life, but metallic sodium is toxic. I don't really know if the current will separate sodium.
Is said pickle still edible after the experiment?
Sure - but it is a little cooked.
We do this all the time in physics, because we can.
Wow!!! Itz cool!!!!
Nice work!!!!!!
Shocking!
You can cook a hot dog that way too.
