Introduction: ElectroPlush - Sleeping Teddy Bear That Wakes Up When Being Touched on the Belly
Materials:
Stuffed Teddy Bear
2 x Arduino Uno
SparkFun MP3 Player Shield
Wires
2 x 10 MegaOhm resistors
Mini Portable Speaker
Diffused Blue 10mm LEDs
High Torque Metal Gear Servo Motor
Zipper
Final Result:
Step 1: Getting the Bear Ready for Hacking
Get a plush teddy bear like the one pictured above, and use scissors to make a cut onto its back, running from its head to its lower back. Get a box and use your hands to unstuff the bear until it is as empty as possible from inside.
Remove the eyes completely by cutting them.
Step 2: Add a 10mm Diffused Blue LED on Each Eye.
Stick the legs of a 10mm diffused Blue LED (http://www.adafruit.com/products/847?gclid=COWGpqCQtLsCFSLxOgodSXMA6g) on each eye with the Negative legs of both LEDs closest to each other, and the Positive legs on the outside.
Solder a wire from both Negative legs and connect them to the Ground of the Shield-less Arduino.
Solder a wire from both Positive legs to Pin13 of the Shield-less Arduino.
Step 3: Add the Serve Motor
Screw in a Servo Motor onto a thick plank of wood the size of the side of the bear's face, and screw in a solid piece of wood onto the arm of the Servo the 1 inch wide and the length of the head of the teddy bear (from back to nose).
Use a glue gun to stick that wood motor piece onto the side of the head in a way that makes the Servo's long wood arm run through the entire head, all the way through to the tip of its nose. Make sure to glue gun all the sides of the plank of wood for better results.
Connect the Signal (yellow) cable to Pin11 of the Shield-less Arduino.
Connect the Power (Red) cable to 5V of the Shield-less Arduino.
Connect the Signal (Black) cable to Ground of the Shield-less Arduino.
Step 4: Make an Arduino Board
Place both Arduinos side by side with a small PCB board in between onto a solid board. You may use screws to secure the Arduinos and the PCB on there.
Step 5: Prepare Your MP3 Shield SD Card
Place the following files onto the root folder of an MicroSD Card and place it into the MP3 Shield. These contain the sound files that the bear will make.
Step 6: Complete the Circuit Board
Use this diagram to complete the circuit. The 2 capacitive sensing boards are actually pieces of conductive fabric connected to the belly of the teddy bear from the inside side by side to detect touch (or push) from the outside.
Step 7: Upload Sketches to Arduinos
Unzip the package below, and upload BearFinal_ShieldLess to the ShieldLess Arduino and BearFinal_SoundVersion to the MP3 Shielded Arduino. You might need to adjust the capactive sensing threshold depending on the way you connected the conductive material and the type of teddy bear you are using. Change the int touchedCutoff to set the threshold to detect the capacitive sensor; higher numbers will decrease how capacitive the sensor is.
Step 8: Put the Stuffing Back in the Bear & Add a Zipper
Carefully start putting the stuffing back inside the teddy bear, and stitch a zipper onto the back opening you have created on the teddy bear's back for easy closure.
Step 9: Wake the Bear Up!
Power up the Arduinos and the speaker. Make the teddy bear lay back and it should start making sleeping sounds. Touch its belly and his eyes should light up, his head should tilt upwards, and he should make sounds that are similar to that of waking up.
2 Comments
7 years ago
Okay question, what wires specifically? In the item list it just says wired..what colours and sizes did you use?
9 years ago on Introduction
Hello)
Very nice job. One question: the touch sensors - are they just the pieces of conductive fabric, or conductive fabric with velostat?
thanks
