Introduction: Electromagnetic Fidget Spinner Accelerator
Fidget Spinners are little plastic toys with a bearing in the center. They are fun for a little bit, but get boring after a while due to their slow spinning speeds. There are ways to make them spin faster, but these methods involve using a bulky air compressor or an expensive can of compressed air. Luckily, I have found a cheap way to accelerate these fidget spinners to extremely high speeds with the power of electromagnetism. You can even hold the spinner in your hand while you accelerate it! I have clocked a spinner that is spinning with this accelerator at speeds up to 1440 RPM, that is fast. You can build this accelerator too, it is really cheap and really simple to build.
The video below compliments this instructable and shows this awesome Electromagnetic Fidget Spinner Accelerator (EFSA) in action!
Lets Get Started.
Step 1: How It Works
This fidget spinner accelerator works by using an electromagnet with a reed switch and a fidget spinner with magnets mounted on the 3 sides. First of all, the magnets on the fidget spinner are mounted so that all the magnets have their north pole facing outwards. The electromagnet is wired so that the side that is closest to the spinner will have a north polarity when it is powered. When the spinner starts spinning (Refer to the above diagram) the electromagnet will be off. As the magnet on one side of the spinner passes the electromagnet, it will trigger the reed switch, activating the electromagnet. Because both magnet and electromagnet will now have the same poles, that arm of the spinner will be pushed away from the electromagnet. When it moves far enough away, the reed switch will disengage and shut off the electromagnet. Because the spinner will be spinning from this first cycle, it will have enough momentum for the next arm to move past the electromagnet and reed switch and repeat the cycle. As each arm moves by the electromagnet and get repulsed, the spinner will speed up and gain momentum. That is how this system of acceleration works!
Now, for how the circuit works. The reed switch alone cannot handle the high currents that the electromagnet draws, so it will need a buffer between it and the electromagnet. This buffer will be a MOSFET transistor. When the reed switch is triggered, it will let current flow from VCC to the gate of the MOSFET. This will allow current to flow form VCC, though the electromagnet, into the drain of the FET, and out of the source back to ground. The diode on the electromagnet is called a flyback diode, and its purpose is to absorb all the excess energy created by the collapsing magnetic field of the the electromagnet. Without it, the MOSFET would potentially be fried. The resistor from the gate of the MOSFET to ground serves to drain the excess charge from the gate after the reed switch turns off. Because the gate of the FET has capacitance to the source, this means that even after you remove power form the gate, the MOSFET will still be on, causing the circuit to constantly be on. The resistor prevents this.
Step 2: Materials
For this project, you will not need very many materials. You will need:
- A 3 arm Fidget Spinner(Well Duh)
- Small Ceramic Magnets
- A piece of perf-board
- An N Channel MOSFET(Almost any one will work)
- A magnetic Reed Switch
- A 10k resistor
- An inductor (More information in step 5)
- A 1n4004 diode
- Wire
- Terminal connectors
- 12 Volt Power Source (Batter or bench power supply)
Step 3: Tools
For this project, the tools you will need are:
- Hot Glue Gun
- Soldering Iron
- Wire strippers/cutters
- Hacksaw
Optional:
- Oscilloscope
Step 4: Setting Up the Spinner
To set up the spinner, you will just need to take three magnets, and hot glue them to the three arms of the spinner. Now, when you attach the magnets, make sure that the same side, or pole, of each magnet is facing out. This means that after you are done gluing them in place, you should be able to take another magnet, and hold it to all the magnets with the same side, and get the same reaction. In my case, there was an indentation on the north pole of the magnet, so all the indentations faced outwards.
You will also need to make sure that you use the same amount of hot glue for each side. If you do not, then your spinner will be unbalanced. It is also important to use a lot of glue, if you don't, then a magnet might fly off due to centrifugal force, also known as tangential velocity. This might cause, I don't know, maybe a dent in the wall? (I know from experience. Haha). It will also cause your spinner to become unsafe. Now, it is time to start building your circuit!
Step 5: Choosing an Inductor
The inductor is one of the most important parts of this project, it acts as the electromagnet that makes the spinner spin. This means that you will have to find the perfect inductor. You can start by digging through your parts drawers of inductors. You will first need to find an inductor that has the perfect resistance, and is not magnetized. Some inductors are magnetized, and these will not work, so before using one, hold it up to a piece of metal. If it sticks, don't use it. You also need to find an inductor with the right resistance. To high of a resistance, and the feild will not be as strong. To low of a resistance, and it will draw too much power. My inductor came out of an old TV board. It is 2.9 ohms and 5.82mH. Make sure that the inductor you choose is made of a ferrous material.
To test your inductor, set you fidget spinner down, and connect the inductor to a power supply. Then, tap the power supply leads on and off the inductor pins while moving it near the spinner. It should cause the spinner to spin! You may have to go though some experimenting to find the right inductor for your project.
Step 6: Cutting the Perf-board
The perf-board is what holds all the components of the EFSA. You will need to cut it so it is large enough to hold all the components for your accelerator, but not too big. You will also need to cut a triangle off of one end to hold the inductor. I made all the cuts in my perf-board with a hacksaw.
Step 7: Soldering the Circuit
This is one of the most difficult parts of this project. You will need to follow the circuit diagram to solder all the parts of the board in place. The positions of the reed switch and the inductor are very important. The reed switch needs to be far enough away from the inductor so that the magnetic field will not cause the circuit to self trigger, but close enough to make the circuit run as efficiently as possible. You will need to do a little experimentation to find this sweet spot. I used screw terminals to connect the inductor and the power wires to the board. You will need to make sure that all the connections shown on the circuit diagram are soldered on the perf-board in real life. Look at the pictures closely to find further know how to solder this board. When you are done soldering the accelerator board, then you should be ready to test it!!
Step 8: Power Supply
This fidget spinner accelerator needs a power supply that can provide 12 volts at 1.5 amps. This power draw will change based on the specs of the inductor you use as an electromagnet. If you just want to use this accelerator at your desk, then you can just connect it to a good bench power supply or computer power supply. If you want to make it portable, then you can use a LiPo or LIon battery. To find out how to make your own 11.1 volt LIon battery, check out my instructable and YouTube video below.
Step 9: Finding the RPM
To measure the RPM of this fidget spinner, all you need is the accelerator and an oscilloscope. First of all, you will need to connect the probe of the scope to the gate of the mosfet. This pin will be high 3 times per revolution because the magnets on each arm of the spinner will trigger reed switch each time they pass it. Then, ground the oscilloscope to the ground of the accelerator. Finally, get a friend to use the fidget spinner accelerator while you look at the oscilloscope. After the spinner was up to full speed, the scope registered a frequency of 72 Hz. This means that magnets were passing the reed switch 72 times per second! You can divide this number by three to find the rounds per second, which would be 24. You can then multiply the RPS by 60 to get the RPM: 1440. This fidget spinner accelerator really makes the spinner spin fast.
Step 10: Have Fun!
To use your spinner with the accelerator, simply hold the spinner with one hand and the accelerator in the other, then give the spinner a little jump start. After that, hold the accelerator closer to the spinner without touching it, and you should see it start to accelerate! The closer you hold the accelerator, the faster it will go!
This device is really a lot of fun. It is especially cool to feel the gyroscopic effect of the spinner at these high speeds. You can also impress your friends by spinning your spinner faster than any of them can. The Electromagnetic Fidget Spinner Accelerator turns a regular old fidget spinner into a truly awesome toy.
Thanks for reading and good luck building! Also, remember to vote for me in the contests!
Third Prize in the
Power Supply Contest
Runner Up in the
Invention Challenge 2017
Runner Up in the
Explore Science Contest 2017
2 People Made This Project!
- talk2bruce made it!
56 Comments
5 years ago
it's like the bedini project. the same principle.
Reply 1 year ago
Sciencing.com just lost any credibility at all with "You don't need to be an expert in electronics to build a Bedini motor. This free energy generating machine[...]"
https://sciencing.com/make-bedini-motor-4704703.html
5 years ago
A sweet little toy. It has potential as with the Bedini Schoolgirl Motor circuit. Try adding a bifilar coil around that six microhenry choke [with an appropriate NPN BJT] wired in and use the back-emf across the choke to charge those batteries. This thing you came up with is actually an attraction motor and when scaled up properly it can take a house off the grid. The house runs on inverters across two sets of batteries, one set of batteries is being charged while the other is powering the house; when power is nor being used it can be sold to the local power company.
Reply 1 year ago
Nice idea, *if* there was any possibility of it working (and there's not.)
If you took a battery and use it to run a motor, you might get 2 hours run time with a particular battery and motor. If you then tried to hook up a generator of any type to charge a second battery, you'd then get less than 2 hours run time but you will have a charge in the other battery. So that seems like you did get extra energy.
But....... The motor may only run for an hour when trying to feed the generator as well. So you took two hours worth of power and now you have only enough power in the second battery for one hour runtime on the motor alone. You reverse the circuit and that battery drains in 30 minutes and puts 30 minutes back into the first battery. So in an hour and a half, you have 30 minutes worth of power left. So at best, you're breaking even and by the time you keep switching and running for half of the time, you get an over-all runtime of....wait for it.... two hours.
So you wound up with no extra energy to feed back to the power company. Not only that but chaining the motor to a generator will wind up with *LESS* than one hour runtime due to increased friction. So your actual runtime at the end of it all becomes an hour and 50 minutes or an hour and 45 mins or whatever (it all depends on the resistance, etc.)
As the saying goes, "there's no such thing as free energy. Not even enough to get you lunch."
Question 2 years ago
Would this get so hot that it burns your fingers if it gets to fast? Can it even get fast enough to get hot?
4 years ago on Step 10
A couple of ideas.....rather than glue magnets to the end of the fidget spinner arms, where they could fly off at high speed, find a spinner which can fit neodymium magnets and squeeze them in. I found a 5-arm spinner which had large ball bearings near the ends. These could be popped out, and the 10mm diameter magnets fitted tightly in the spaces. The magnets need to have their S or N pole sides all facing up in the same orientation.
See photo.
I also changed the reed switch for the A3177 Hall Effect sensor, which allows faster rotation of the spinner. See circuit diagram.
Reply 3 years ago
I already bought the parts for the other accelerator using the Reed sensor....but your configuration was so much easier to understand. Can you do me a huge favor and rewrite the diagram in a configuration with labels like you did for yours, but using his diagram with the Reed sensor?
This would help me a lot...send me your cash app $ and I'll send you a few bucks for your time.
Thanks- rod
Reply 3 years ago
Making two... with my son for a science project...
Question 4 years ago on Introduction
Can I have the write-ups for the above model .i.e., the main purpose of the experiment, its aim, theory, uses, practical applications nd precautions nd sources of error?
5 years ago
Is there anyway to control the speed? For example between 500-1000 rpm?
5 years ago
hello, can you make it faster like 10000 or 20000 rpm ?
if not , why only 1440 rpm?
Reply 5 years ago
I would think the reed switch could effectively limit the speed as it is a mechanical device. If there is a solid state alternative available, it might allow for faster revolution.
As well, mounting the spinner and 'accelerator' so as to allow better control of proximity as well as a 'steady rest' might well allow for better performance.
Reply 5 years ago
A hall-effect sensor would be a big improvement over a reed switch. Once you overcame the limit of having a mechanical switch, it could theoretically accelerate until the air resistance (drag) equals the force applied by the electromagnet, causing a net force of zero and therefore no acceleration. That is, assuming there wasn't any other bottleneck component like the speed of the transistor.
5 years ago
This is a fantastic project and I think it has the potential of educating my boys in a number of ways. My problem is that I don't have a "drawer of inductors". Can you recommend a model/part that I could find on Amazon or at Micro Center?
Reply 5 years ago
I have the same issue - all the inductors I tried were magnetic. Any luck finding a non-magnetic 5nH inductor?
5 years ago
Hmmm how about the power of light? I have some 2 watt lasers that pack a punch ( goggle mandatory ) but perhaps photons can spin something for fun? I may try this.
5 years ago
Very clever. Thanks. I'll make one tonight. Of course you have just reinvented the electric motor.
5 years ago
Beware, this might set you off to build Bedini machines...
Here's an oooold book, older than even me, that you might like:
https://sites.google.com/site/buildyourstuff/practical-machinist-watch-and-learn
5 years ago
Not sure if my last nearly identical comment went through (bad WiFi connection and browser keeps crashing) but I meant to say this is way cool!
5 years ago
This is super cool. Congrats!
