Introduction: Electronic Light Sensor Piano
This is a project that allows you to play piano by covering light sensors
Step 1: Parts
1. Arduino Uno
2. Breadboard
3. Male wires
4. Light sensor
5. Resistor
6. Speaker
Step 2: Set Up
1. Place 5 light sensors in breadboard
2. Connect each light sensor to different pins using male wires
3. Connect each light sensor to Ground, with a resistor to limit the amount of energy that flows
4. Connect each resistor to 5v
5. Connect a speaker to ground and pin using male wires
6. Play the piano by covering each light sensor at different times
Step 3: Code Part 1: Define Gives Each Note a Tone
//#include "pitches.h"
#define NOTE_B0 31
#define NOTE_C1 33
#define NOTE_CS1 35
#define NOTE_D1 37
#define NOTE_DS1 39
#define NOTE_E1 41
#define NOTE_F1 44
#define NOTE_FS1 46
#define NOTE_G1 49
#define NOTE_GS1 52
#define NOTE_A1 55
#define NOTE_AS1 58
#define NOTE_B1 62
#define NOTE_C2 65
#define NOTE_CS2 69
#define NOTE_D2 73
#define NOTE_DS2 78
#define NOTE_E2 82
#define NOTE_F2 87
#define NOTE_FS2 93
#define NOTE_G2 98
#define NOTE_GS2 104
#define NOTE_A2 110
#define NOTE_AS2 117
#define NOTE_B2 123
#define NOTE_C3 131
#define NOTE_CS3 139
#define NOTE_D3 147
#define NOTE_DS3 156
#define NOTE_E3 165
#define NOTE_F3 175
#define NOTE_FS3 185
#define NOTE_G3 196
#define NOTE_GS3 208
#define NOTE_A3 220
#define NOTE_AS3 233
#define NOTE_B3 247
#define NOTE_C4 262
#define NOTE_CS4 277
#define NOTE_D4 294
#define NOTE_DS4 311
#define NOTE_E4 330
#define NOTE_F4 349
#define NOTE_FS4 370
#define NOTE_G4 392
#define NOTE_GS4 415
#define NOTE_A4 440
#define NOTE_AS4 466
#define NOTE_B4 494
#define NOTE_C5 523
#define NOTE_CS5 554
#define NOTE_D5 587
#define NOTE_DS5 622
#define NOTE_E5 659
#define NOTE_F5 698
#define NOTE_FS5 740
#define NOTE_G5 784
#define NOTE_GS5 831
#define NOTE_A5 880
#define NOTE_AS5 932
#define NOTE_B5 988
#define NOTE_C6 1047
#define NOTE_CS6 1109
#define NOTE_D6 1175
#define NOTE_DS6 1245
#define NOTE_E6 1319
#define NOTE_F6 1397
#define NOTE_FS6 1480
#define NOTE_G6 1568
#define NOTE_GS6 1661
#define NOTE_A6 1760
#define NOTE_AS6 1865
#define NOTE_B6 1976
#define NOTE_C7 2093
#define NOTE_CS7 2217
#define NOTE_D7 2349
#define NOTE_DS7 2489
#define NOTE_E7 2637
#define NOTE_F7 2794
#define NOTE_FS7 2960
#define NOTE_G7 3136
#define NOTE_GS7 3322
#define NOTE_A7 3520
#define NOTE_AS7 3729
#define NOTE_B7 3951
#define NOTE_C8 4186
#define NOTE_CS8 4435
#define NOTE_D8 4699
#define NOTE_DS8 4978
Step 4: Code Part 2: Assign Pinmodes and Establish Integers
int melody[] = {
NOTE_C4, NOTE_G3, NOTE_G3, NOTE_A3, NOTE_G3, 0, NOTE_B3, NOTE_C4
// note durations: 4 = quarter note, 8 = eighth note, etc.: int noteDurations[] = {
4, 8, 8, 4, 4, 4, 4, 4
void setup() {
// put your setup code here, to run once:
pinMode(A1, INPUT);
pinMode(A2, INPUT);
pinMode(A3, INPUT);
pinMode(A4, INPUT);
pinMode(A5, INPUT);
pinMode(8, OUTPUT);
Serial.begin(9600);
/*for (int thisNote = 0; thisNote < 8; thisNote++) {
// to calculate the note duration, take one second divided by the note type.
//e.g. quarter note = 1000 / 4, eighth note = 1000/8, etc.
int noteDuration = 1000 / noteDurations[thisNote];
tone(8, melody[thisNote], noteDuration);
// to distinguish the notes, set a minimum time between them.
// the note's duration + 30% seems to work well:
int pauseBetweenNotes = noteDuration * 1.30;
delay(pauseBetweenNotes);
// stop the tone playing:
noTone(8);
Step 5: Code Part 3: If the Light Sensor Is Covered, Then Play a Tone
void loop()
// put your main code here, to run repeatedly:
int ldr1 = analogRead(A1);
int ldr2 = analogRead(A2);
int ldr3 = analogRead(A3);
int ldr4 = analogRead(A4);
int ldr5 = analogRead(A5);
//Serial.println(ldr5);
if (ldr1 > 500)
{tone(8, NOTE_A3);}
else noTone(8);
if (ldr2 > 300)
{tone(8, NOTE_C4);}
else noTone(8);
if (ldr3 > 210)
{tone(8, NOTE_D4);}
else noTone(8);
if (ldr4 > 400)
{tone(8, NOTE_E4);}
else noTone(8);
if (ldr5 > 310)
{tone(8, NOTE_C4);}
else noTone(8); }
