Introduction: Electronic Ring
Welcome to this instructable !
I will show you how to make this ring with a led.
You will need :
-a LED
-17/18/19 AWG copper wire
-31/32/33 AWG copper wire
-small insulated wire (I use a paperclip)
-aluminum tape
-universal glue
And some tools :
-soldering iron
-pliers
-lighter
Step 1: Prepare the Copper
First, you need copper. I use a 18 AWG copper wire.
Measure the circumference of your finger and cut the same length of wire.
The insulation must be removed.
Twist the copper so that it has the shape of your finger. You can use a round tube.
Take the lighter and pass the copper in the flame to give a gray effect and harden the metal.
File the ends to avoid injury.
Step 2: Attach the LED
Now we are going to fix the LED on the ring.
You can use all round LED, even those that do not work anymore.
Spread the wires of the LED and wind each wire on one end of the copper.
Take your soldering iron and weld each side with the least tin possible (do not use lead for objects in contact with the skin !).
Be careful that the ring is still the size of your finger.
When the LED is soldered, file the solder.
Step 3: Finish the Assembly
Now you have to do the details.
Take a small piece of insulated wire or a paperclip and wrap it around the copper from one weld to the next (12 to 15 turns).
You can use glue to fix the wire or you can solder it.
Then gently wrap some aluminum tape over the welds.
And finally wind very thin copper wire (I use 32 AWG) between the LED and the aluminum tape and fix it with glue.
Done !
