Introduction: Electronics Building Tips ( in 21 Plus Steps )
I have been building circuits for a long time and may have picked up some ideas that may be new to more recent builders. There is nothing very hard or astonishing about the tips but they have helped me and may help you too. In my mind a tip is not an electronics project ( but occasionally may involve putting together a mini-project ) or full directions on say "how to solder". A tip is more a little trick in technique or approach. All of the following should fit this definition.
Step 1: Cardboard Parts Holder
When you are building, and particularly prototyping you tend to have a lot of parts, often ones that look alike, hanging around. Put them down and who knows what value they are. Good old Heathkit ( RIP http://en.wikipedia.org/wiki/Heathkit ) had a nice solution, insert the leads in corrugated cardboard and identify the part by writing on the cardboard. Pictures will stand in for the next 1000 words I might otherwise write.
Step 2: Ignore the Resistor Code
You can get all sorts of calculators etc for decoding resistor color codes and values. I say throw them out. Even if you know the codes it is easy to misinterpret the colors, and many resistors, like most 1% ones do not use the color code. Instead it is easy to measure them. Leave out a meter set on resistance and give each part a quick check before you use it. Do this even if you have pre-sorted the resistors, it is easy to miss-sort. The device in the picture helps. You might want to build one of these and keep it on the bench while you are building: Third Hand for Your Multimeter by russ_hensel https://www.instructables.com/id/Third-Hand-for-Your-Multimeter/
The same thing pretty much true of small caps: use a capacitance meter.
Step 3: Banana Plugs and Jacks
Banana plugs look a bit like a very small metal banana. They are very useful as they plug into a lot of things. Especially banana jacks ( see picture ). But you should also know they fit lots of other things. Most binding posts have a jack built in. ( see picture ). My favorite banana plugs are called stackable banana plugs, they have a jack at the back, and you can plug one into another and stack them up see the pictures. Pamona makes them, not sure what the best source is but here are a couple of links:
Banana plugs also fit some other things, one very handy thing is the standard alligator clip ( see picture ) Using the alligator clip is usually better if it wears its boot.
If the banana plug does not fit, perhaps you should adapt it, the pictures show how some tubing and banana jacks can be added to a test probe to make the probe jack-able.
Step 4: Make Adapters
The banana plug adapters are not the only ones you can make. Just one example: Make a jack for a meter probe. Mine is made from a bit of bare wire, wrapped to fit the probe and then soldered to the clip. I needed a little tape on the boot at the end. ( see pictures )
A very fancy adapter I made for RS232 cables is: Tea Connector for Serial RS232 Cables by russ_hensel https://www.instructables.com/id/Tea-Connector-for-Serial-RS232-Cables/
In fact adapters were an early theme of mine on instructables:
- Audio/Video Cable ( RCA Connector ) Splicer/Splitter from Salvage by russ_hensel https://www.instructables.com/id/AudioVideo-Cable-RCA-Connector-SplicerSplitter-fro/
- A Really Simple RS232 9 pin Sex Change. by russ_hensel https://www.instructables.com/id/A-Really-Simple-RS232-9-pin-Sex-Change./
Sometimes it may even be useful to buy adapters ( see pictures ).
Step 5: Look Up the Datasheets
If you are using a component go on the web and look up its datasheet ( use the part number and the keyword “datasheet” ) Not only will it give you the parameters of the part, but the pinout, and often, useful circuits. Also use the keyword “application note” ( sometimes “app note” ) which may or may not exist for your part. Typically they are loaded with useful circuits. Oh and "rtfm": read them.
Step 6: Print Pinouts
When prototyping it is nice to know what pin on an IC is what. You can grab the pinout pictures from the data sheets ( for example the 555 from http://www.ti.com/lit/ds/symlink/lm555.pdf ) The pinout is usually the top view. If you are working on perf board you really need a bottom view. To get this just use your image editor ( I use paint shop pro ) to miror the picture. These pictures can then be added to a document ( I use open office ) with both a top and bottom view or multiple parts. You can annotate the document as you want. Print it out and hang it up over your prototyping area while you work.
Step 7: Make Sure You Can See
Use lots of light, a swing arm desk lamp like this I have several in the lab. Since my work bench is just a sheet of plywood with some reinforcing around the edge, I make lots of extra mounts for the lamps by drill the appropriate size hole in edge. Now I can move the lamp to the best position easily. ( interesting how many swing arm lamps there are see: http://en.wikipedia.org/wiki/Balanced-arm_lamp )
A head mounted magnifier keeps getting more useful as parts get smaller and your eyes get older. This cheap Harbor Freight one works for me. I like this better than a magnifier in my hand or even on an adjustable arm. ( http://www.harborfreight.com/magnifier-head-strap-with-lights-38896.html and one I like a bit better <now gone it is the one in the picture> Not sure this is useful but "great look" http://www.amazon.com/Watch-Repair-Magnifier-Loupe-Glasses/dp/B007YBEHIO/ref=sr_1_4?ie=UTF8&qid=1389025042&sr=8-4&keywords=magnifier+glasses and finally the ones I think HF used to carry: http://www.amazon.com/Headband-Glasses-Magnifier-Reading-Antiques/dp/B004WRN5HM/ref=sr_1_2?ie=UTF8&qid=1389025042&sr=8-2&keywords=magnifier+glasses )
Step 8: Nut Starter
This is not really electronic, but often you need to assemble your project. Sometimes this involves starting a nut in a place that is really hard to reach. Heathkit had a solution, a nut starter. Basically this is a rod with a recess that just fits the nut. The recess should be somewhat elastic, plastic, rubber.... You place the nut into the recess, then you can reach way in and get the nut started. Not too hard to make, a different one for each size nut. You can even buy them. http://mendatools.descoindustries.com/MendaToolsCatalog/SpecialtyTools/35120/#.UrG--kD4tbI
Step 9: Coin Envelopes
Coin envelopes are small paper envelopes. Use them for small parts. Why? Because they are cheap , a couple of cents a piece, you can write on them, and they are stiff enough to line up in drawers of boxes. Check them out in the pictures. They come in various sizes. Get them at stores like Office Max or at Amazon perhaps http://www.amazon.com/Columbian-CO540-4x3-1-2-Inch-Envelopes/dp/B001IZF7GI/ref=sr_1_1?ie=UTF8&qid=1387420248&sr=8-1&keywords=Coin+Envelopes
Step 10: Strain Relief
Wires that will move or be pulled on after construction should have strain relief. This means that the wire will not pull on its electrical collection. There are many ways to do this, grommets, clamps, hot glue. On a perfboard you can weave the wire through and extra hole.
Step 11: Color Coded
When wiring use different colored wires. This makes keeping track of the wiring much easier. Salvaging wire from cat 5 cable gives 8 different colors. Solid color wire can be striped by pulling it by a felt tip marker. For power stick with the convention that plus power is red, ground is black or green, and negative power is ( for me ) blue.
When you buy connectors, jacks, jumpers..... think about the colors and buy them in as many different colors as you can get. The Pamona stackable banana plugs I recommended above used to come in about a dozen different colors, seem hard to find now.
Ribbon cable comes in a multitude of colors, peel off what you need, sometimes it is handy that you can get more than one conductor in a unit.
If you need more colors for things like binding posts the paint for plastic models ( cost 15 cents when I first bought them ) can be useful. For fatter cables you can use colored electrical tape ( like: http://www.amazon.com/3M-Electrical-Tape-9-Pack-Color/dp/B000PHGM14/ or http://www.amazon.com/Duck-299020-Colored-Electrical-Multi-Color/dp/B001B175J6 ) add a colored band to each end of the cable to create variants: gray with a red band for example.
Step 12: Test Points
Test points are places in the circuit that are easy to connect to and support a signal of interest in debugging a circuit. The output of an amplifier stage might be a good place for a test point A small loop of wire, then end of a component or a piece just soldered in to make the test point can be used as a point of attachment. Make them as small as you can, but big enough for your smallest grabber. When the circuit is working leave the test points unless they are in the way, to remove, clip off flush with the board.
Step 13: Keep It Neat
A messy breadboard is very hard to debug. You connect up wires wrong, and have trouble tracing the leads. If they are just the right length and hug the board they are easy to see and do not snag on test leads etc. It can be a bit of a pain, but it quickly pays off. Use in conjunction with color coding. The same applies to more permanently built circuits.
It is unfortunately too easy to find terrible examples of breadboard wiring on instructables -- you guys clean up your act.
Step 14: Take Pictures
Take pictures of circuits either to debug or repair. Especially useful if you are trying to draw a schematic of an undocumented circuit. Take from both sides. By mirroring you can be looking at the bottom while looking at a picture that shows the location of the parts on top. Those of you who are clever ( not me ) may be able to figure out how to make the two sides different colors and then superimpose to get an X-ray like view. If you figure this out let me know.
Step 15: Preset Strippers
Some strippers, particularly cheap ones are adjusted with a nut and bolt. Usually a pain to get just right. When you get them just right for a size of wire you commonly use, set them up tight, label them, and then don't change them. Need another size - use a different pair these are the cheap guys. Most of us commonly work with a small set of wire sizes so we should need only a few pairs.
Step 16: Use Needle Nose Pliers
When you push a wire or component lead into a breadboard, it often does not want to go in, so the lead crumples up. Make it a habit of using needle nose pliers for the insertion. Grab the lead just far enough from the end to insert it all the way, then push. Works much better. Of course there are lots of other uses for the pliers. Harbor Freight has reasonable pairs cheap.
Step 17: Soldering Tips
- Unfortunately solder with lead in it works better than the newer lead free solders. I normally use it but try to stay out of the fumes.
- Solder does not make a very strong joint, best if you have a mechanical joint first, but often this is hard. Also try to maximize contact area of the joint to make it stronger.
- Clean parts, particularly if old or oxidized before putting in place, I like 600 grit wet or dry paper, never use steel wool near you electronics work place.
- If the solder is not "sticking" a little scraping with a sharp blade may help. A bit of extra flux ( non corrosive please ) may also help.
- Inspect all joints just after soldering. With point to point wiring where the solder provides the only thing holding the joint together try ( not too hard ) to pry it apart.
- Keep the tip of the iron clean, damp sponge is fairly standard, wipe most every time. Good tips are often plated, do not get too aggressive and remove the plating.
- Remember solder when liquid tends to move towards the greatest heat.
- Pre-tinning is often helpful, always consider doing it.
- A temperature controlled iron is so much better than one that is not. Need not be really fancy. One in the picture is 40 years old, replaceable tips, still available.
Step 18: Miscellaneous Tips
- For integrated circuits and microcontrollers, use a socket rather than direct mounting of the component.
- For experimental circuits assemble and test one stage at a time.
- Power up without the chips and check voltages like power and ground. Also check continuity.... to make sure what you built is what you planned.
- Feel the chips to see if they are running hotter than they should.
- Powering up from a current limited power supply often keeps in some of the magic smoke.
Step 19: Power
Use wall warts ( the little blocks that plug directly into the wall and provide power ). Why? Someone else has built most or all of the power supply and you are safer without any line voltage in your project. For 5 volts a “usb” power supply is cheap and they are ubiquitous. A usb hub with a bunch of ports and external supply will let you power multiple projects at once. ( By the way the idea of building “usb” projects like fans and leds and plugging them into your computer is sort of foolish, usb is universal serial bus, these projects are just using the power lines, nothing serial about them. It is generally not a great idea to use a $500+ computer as a power supply. /rant ) Be careful to check the ripple and regulation of the supply, many are very poor. Consider adding a regulator ( next tip ).
Three terminal regulators are incredibility easy to use. LM7805 and similar parts are typical. They are often “short circuit proof”, use low parts count, come in many voltages ( or are easily adjusted ) and cheap. Many an instructable has been published basically using the circuits that come right is the datasheet. Adding to the back end of a wall wart makes a badly regulated wall wart behave, at a slightly lower voltage than the wall wart name plate.
Use batteries. If you need to be unplugged. If you are connecting your project electrically to a person or animal, then it should be battery powered. This can save a life. This applies to a computer as well, do not plug in and connect to a living thing.
Step 20: Cases for Your Project
On instructables you see a lot of projects that are not in cases. This is, in part, because cases can be expensive, hard to find, and tedious to implement. But a nice project deserves a case, and if the voltages are high pretty close to mandatory.
On useful feature of a case is that the material is easy to work ( wood, aluminum come to mind ) and thin enough so pots switche, binding posts etc mount nicely. A case that is mostly unfriendly, say steel, may be OK if you use an aluminum or plastic face plate.
You should scavenge for cases, I use old tea tins ( see Tea Connector for Serial RS232 Cables by russ_hensel https://www.instructables.com/id/Tea-Connector-for-Serial-RS232-Cables/ ) metal cookie boxes, plastic file cared cases and even plastic jars. Altoid tins are popular for smaller cases ( like the classic minty boost. ). If you salvage some piece of equipment always consider saving the case.
There are some tools that are useful for case work. You should know what, drills, files, nibbling tools, reams, step drills and chassis punches are. Then you can decide which to use.
Step 21: Breadboards
Great for prototyping, not so great for permanent projects as the parts and wires have a tendency to fall out. You can recreate it with a custom printed circuit board, or use point to point wiring on .1 inch perf board ( link ). There are even pre printed circuit boards ( like:
- http://www.jameco.com/1/1/421-br1-solderable-pc-breadboard-1-sided-pcb-matches-830-tie-point-breadboard-power-rails.html
) that pretty much mimic a proto board but where you solder the component in.
For tips on using bread boards see my instructable: Comprehensive Guide to Electronic Breadboards: A Meta Instructable by russ_hensel https://www.instructables.com/id/Comprehensive-Guide-to-Electronic-Breadboards-A-Me/
Step 22: Diode in Power Connection
If you are powering your circuit from a power supply or similar it may be easy to connect the supply backwards. This may let the magic smoke out of your parts. If so put a diode in the supply line to block reverse voltages.
Step 23: Electricity Can Kill
But it should not kill you. Under 30 volts things are pretty safe. Dry hands and care help. Grounding yourself is not a good idea, if you do it for ESD issues do it through a high value resistor. Shocks across the chest are very dangerous because that is where most of us keep our heart. Keep one hand in your pocket and you will not get a shock across your chest.
Step 24: Make a Circuit or Buy an IC?
If you a working on a project sometimes you will end up designing something that may seem a bit complicated. Two examples: a high side driver or a high side current sensor. Both can be done without great trouble, and perhaps with parts you have on hand. But also consider using an integrated circuit for the task. Both of these have fairly cheap and simple to use IC that you can just buy. Find the datasheets and any application notes.
Step 25: Plugging in Old Equipment
Old equipment that has been out of use for a long time may fail, and dramatically if the old electrolytic caps are shot. Some people just recommend that you open up the equipment, rip out the caps and replace. Sometimes they can be saved with the right start up procedures.
The basic idea is that in an electrolytic cap the dialectic is formed by the interaction of the chemicals in the cap with the applied field. The dialectic fades away with time but can be rebuilt by gradually applying a voltage. Google reforming electrolytic dielectrics.
Methods to do this vary, the simplest is to plug the device into a variac and slowly bring up the voltage. A meter across the cap is very useful.
The ideal method from the point of view of control is to break the v+ connection on the cap. Then connect an external power supply ( perhaps through a high value resistor ) and measure both the current and voltage for the cap. Slowly bring up the voltage. Watch the current, it should go to a very low value. Keep increasing the voltage until you reach the working voltage of the part and you are done. It the current stays high, both you and the cap are done. This process can take from perhaps 5 minutes to an hour.
I used this technique in: A Tale of 3 Oscillators – Fixing Old Electronics by russ_hensel https://www.instructables.com/id/A-Tale-of-3-Oscillators-Fixing-Old-Electronics/
Step 26: Tips on Instructables
- The Greatest Electronics Tip I Know -- The Spudger by pfred2 https://www.instructables.com/id/The-Greatest-Electronics-Tip-I-Know-The-Spudger/
- PCB Soldering Tip #1: Tape by Radioactive_Legos https://www.instructables.com/id/PCB-Soldering-Tip-1-Tape/
- Electronics Tip - Meter Probe Protectors by uhclem https://www.instructables.com/id/Electronics-Tip-Meter-Probe-Protectors/
- Stripboard track cutter by scraptopower https://www.instructables.com/id/Stripboard-track-cutter/
- 7 reasons Your Circuit Isn't Working by mikey77 https://www.instructables.com/id/7-reasons-Your-Circuit-Isnt-Working/
- How to Easily Solder Wires to SMT LEDs by ProvideYourOwn https://www.instructables.com/id/How-to-Easily-Solder-Wires-to-SMT-LEDs/
- NiftyBender Deluxe - A tool for the stripboard user. by AndyGadget https://www.instructables.com/id/NiftyBender-Deluxe-A-tool-for-the-stripboard-use/
- Soldering Sockets and Header Pins on Straight by amandaghassaei https://www.instructables.com/id/Soldering-Sockets-and-Header-Pins-on-Straight/
- Repair your electronics by replacing blown capacitors by fhidiort https://www.instructables.com/id/Repair-your-electronics-by-replacing-blown-capacit/
- Watch for more instructables by me! Already working on 2 more on electronics tips. Why not subscribe?
- Already mentioned, but will say again see: Comprehensive Guide to Electronic Breadboards: A Meta Instructable by russ_hensel https://www.instructables.com/id/Comprehensive-Guide-to-Electronic-Breadboards-A-Me/
34 Comments
9 years ago on Step 26
A good collection of tips, but I would like to add one:
Solder an alligator clip to a banana plug so you can plug it into your DVM with the clip pointing up. Then you can put a component into the clip both to make a connection and to hold it in place while you probe it with a test lead.
I welcome everyone to add more as comments. Thanks
9 years ago
damn good. a very cool guide to ease and safety. keep it up.
Thanks, the response has been very encouraging. Thus I am working on 2 more sets of electronics tips, one centering on getting and using test equipment. Would you be surprised that quite a bit of effort goes into this? May be published soon or could take a few weeks.
9 years ago on Step 19
Looking at your picture of your wall warts, I have two additional tips:
1) keep each wall wart in a small plastic zip-lock bag instead of all of them in a box. This will keep them from entangling with each others cables
2) look out for discarded cell phone chargers. These are usually 3.6V or 5V regulated wall warts which can easily be reused in many projects.
Reply 9 years ago on Step 19
I do that with some components, perhaps I should with wall warts too. Normally on anything I store I use a twist tie to collect the cord. The wall warts go in cat food buckets based on voltage output. I have about 5 buckets, but you cannot have too many.
Reply 7 years ago
#1 is a really good Idea, Uwezi, thanks!
8 years ago on Introduction
Very, very good collection of tips! Thank you. I use most of these tips myself but am glad to see that someone else has explained them in a straight-forward manner. I am almost embarrassed to admit that, I too, have about a cubic foot of wall warts - but they're so damn handy to have.
8 years ago on Step 7
I have a cantiliver light with broken mount and was wondering what to do with it. Drill hole in benchtop and a bolt from underneath. Great idea
Where do you still find the soldering tips for your old Weller soldering station? I have a similar unit. Thanks
Try this:
http://www.tselectronic.com/shop/product/Weller-PT...
Love the tips all of them are very useful. One thing though its not voltage that kills its current, 100 to 200 milliamps across the heart is all it takes to induce ventricular fibrillation and stop the heart. Above and below this wont kill you but it will hurt. Also I love the soldering iron, I still use that exact model at work and it's working like a champ.
9 years ago on Step 23
I found this Instructable so usefull ! There are many small tips that I can apply to the hobby I have enjoyed all my life . Your work bench reminds me of my Father's ...and that is a good thing ! We both shared a love and respect for electronics from tubes through transistors and into intergrated circuits. He passed just after I started exploring micro's , but I will always be gratefull for his creative thinking and problem solving.
I am looking forward to reading more of your instructables !
Many , many thanks to you for sharing your wisdom and knowledge ,
Build_it_Bob
Reply 9 years ago on Step 26
Thank you.
I like my bench, but my wife not so much.
Have a few insturctables about 90 percent done, it is the last 10 percent that takes 90 percent of the time.
Russ
I like the coin envelopes idea. I used 2x2 clear resealable bags from Hobby Lobby. You can get 100 or so of them for 2 or 3 dollars. Labeled those then put them in something like this:
Came in pretty handy in EE classes.
Yes I like the 2x3 clear ones with the white block for writing, so I can see and read what's in there :-). Amazon had 1000 for about 9 bucks. http://goo.gl/SJdmgG
The reason I do not like the bags so much is that they are limp and hard to write on/read. For larger parts I do use a bunch of ziplock bags and throw the stuff in boxes. Lots of people do like the small ones. I think there may be some instructables on them including putting in notebooks.
I agree. Trying to find something that would write on them was very difficult. I used a sharpie at first but ended up going to a label maker instead. But for what you were using them for above, I like your idea better. The stiffer envelopes definitely take the cake.
Wow, someone knows about Heathkit.
Then, I must know even less (even after building a TV in the early 70's) for I didn't realize they tried a reentry in 2011
Nice ideas. Yes, their kits were very organized.
