Introduction: Elementary Circuit Simulation_circuit Wizard
Its the elementary circuit simulation in circuit wizard.Circuit wizard is a is a revolutionary new system that combines circuit design, PCB design, simulation and CAD/CAM manufacture in one complete package.
Step 1: Circuit Wizard Downlaod
Step 2: Features
Circuit diagram design
Yes
Component library (# of models, click here for details) 1500+
GENIE microcontrollers (see genieonline.com) Yes
ANSI and DIN symbols Yes
Schematic capture Yes
Virtual instruments 7
Virtual test probes Yes
Automatic wiring Yes
Nets and virtual connections Yes
Interactive circuit diagram simulation Yes
On-screen animation Yes
True analogue/digital simulation Yes
Simulation of component destruction Yes
Component fault simulation Yes
Customizable component library (click here for details) Yes 1
Interactive component and pin hints Yes
PCB layout PCB layout design Yes
Off-board components Yes
Interactive PCB layout simulation Yes
Breadboard simulation Yes
Virtual instruments 5
Automatic PCB routing (# of layers) 1 / 2
Routing of flying wire links Yes
Interactive PCB routing Yes
Bill of Materials reporting Yes
Create your own subsystem blocks Yes
Design quality checking Yes
CAD/CAM Panel design (see genieonline.com/design) Yes
Dimensioning and labelling tools Yes
DXF export Yes
Gerber export (274-D / 274-X format) Yes
NC-Drill export (Excellon format) Yes
General Resource Centre for help with GENIE programming. Multi-level zoom (25%-2000%) Yes
Multiple undo and redo Yes
Copy and paste to other software Yes
Multiple document support Yes
Full-screen whiteboard mode Yes
Auto fit graph axes Yes
Automatic save Yes
Integrated text and drawing tools Yes
Courseware authoring tools Yes
Software access customization Yes
Network support (click here for details) Yes 2
Step 3: Requirements
You will need at least
the following specification to run Circuit Wizard: IBM-compatible PC with an x86 processor (CPU) Microsoft Windows XP, Vista, 7 or 8 Operating System (OS) 256 MB of (RAM) memory (memory requirement excludes that required by your OS) 100 MB of available hard-disk space VGA or higher-resolution monitor Microsoft mouse or compatible pointing device
