Introduction: Embossed Tinfoil Bracelets
This is how to make SUPER simple bracelets with only a few materials! You probably already have these items at your house, so here is how to make them-
-tinfoil
-hot glue gun
-card stock paper
-paint (optional)
Step 1: Planning
The first thing you need to do is make the correct sized paper for your bracelet. Cut a strip and use your own wrist for reference of how long it should be. Make sure to leave about an inch of extra paper than you actually need. Mark off where the extra inch is (mine is marked with an x) After that, you can draw whatever design you can think of for your bracelets to have on them!
Step 2: Hot Glue
Next take your hot glue gun and go over the lines that you drew. Make sure that if your hot glue gun leaves any strings of glue you get rid of them because they might affect how the final piece turns out.
Step 3: Tinfoil
For this step, grab a pretty large piece of tinfoil. After the hot glue has dried, wrap the tinfoil around your paper, then make sure to glue it shut and cut off the excess tinfoil. Then, press down the tinfoil all around the hot glue. Since the hot glue dries hard the tinfoil will cover your design and make your design stand out.
Step 4: Painting (this Step Is Optional)
If you are satisfied with the way your bracelet looks with just the tinfoil, you can leave it there. But you can also paint it to make it look even cooler!
Step 5: Close the Bracelet, and You're Finished!
Glue the bracelet shut, making sure to cover the extra paper on the end. And that's it! They are super easy and fun to make! Thank you for reading, and I hope you have as much fun making this as I did!
