Introduction: Embossing a Moleskin With Gears
As we all know, there are more than 62 Projects to Make with a Dead Computer
One such project is embossing a notebook with gears. The execution of the project was not the greatest and I was never really happy with the fact that you never really technically ended up with anything new made out of old computers. Nonetheless, it did make into the book as a footnote to project 4, as something you can do with all of those extra gears.
Anyhow, here are some full instructions for embossing a notebook using gears, when starting with a dead optical disc drive.
You will need:
1) A broken CD or DVD drive
2) A moleskin notebook
3) A table vise
4) A C-Clamp (or two)
5) Two wooden boards slightly bigger than your notebook
6) A Phillips screwdriver
7) A computer tower or chair
Step 1: Open
Disassemble your CD drive until you have located the laser diode mechanism. Remove the ribbon cable connected to the laser’s circuit board to use later as a bookmark.
Step 2: Remove Gears
Remove the gears from the laser diode assembly.
Step 3: Trim Gears
Trim the hubs off the gears so that they are completely flat.
Step 4: Arrange
Arrange the gears on your moleskin notebook as you wish for them to appear. Make sure that the trimmed side is facing up. The clean side of the gears should be flush against the surface of the notebook.
Step 5: Sandwich
Sandwich your notebook and gears between two pieces of wood. When you do this, be careful as to not move the gears.
Step 6: Clamp
Clamp your sandwiched notebook using your table vise. Also attach a C-clamp or two to such that they provide uniform pressure over the surface of the wood.
Step 7: Wait
Wait 30 minutes to an hour.
Step 8: Admire
Remove the clamps from your notebook. Insert the ribbon cable bookmark and admire your creation.
