Introduction: Emergency Coin Safe - Puzzle - 3D Printed
It's a pretty silly idea to keep a few coins or a banknote as a nest egg in a box like this, especially as you then have to know how to open it.
This small safe box, consisting of three printed elements, has it all. The bottom element contains a cavity in which small objects such as rings, coins or a folded note can be stored. An ideal little gift for family and friends ... with a lucky penny inside, for example!
The idea for this object came to me through the publication of the Nickel Puzzle Box by scorch on Thingiverse https://www.thingiverse.com/thing:1584817. He in turn got the idea for his realisation from Craftmanspace https://www.craftsmanspace.com/free-projects/ball-puzzle-box-plan.html#google_vignette. About twice the size of my model and made of wood. My design is a combination of both - 3D printed.
If you don't know the trick, opening this small safe requires a lot of patience! Many give up. Sometimes the solution is found by chance ... which does not mean that the solution has been found!
It is relatively quick to make … if the necessary parts are available 😉
Dimensions: L60xW30xH30
You need:
- 3D printer
- filament (different colors)
- Phillips screw Ø 4 x 30 mm
- self-locking nut Ø 4 mm
- steel ball Ø 7 mm
- Phillips screwdriver
Step 1: Printing
Print settings:
- printer brand: Prusa
- printer: MK3S, Mini
- supports: no
- resolution: 0,2
- infill: 15%
- filament brand: Prusa; ICE
- filament color: Galaxy Black; Romantic Red, Wintershine White
- filament material: PLA
Remark: As all parts are designed to fit very precisely, it may happen that you have to rework one or the other part a bit with sandpaper and/or cutter due to different dimensional accuracy of the printers and the different behavior of the filaments.
Step 2: Assembly
For the assembly you need:
- the printed parts
- steel ball Ø 7 mm
If possible, a self-locking nut should be used, as a normal nut would quickly come loose due to the rotational movements.
With the help of the pictures you can place the 3 parts on top of each other. But don't forget to place the ball in the recess in the middle section.
Step 3: How to Open the Safe
As you have assembled this object yourself, the solution will surely be clear to you. For all those who just want to have a look at this publication, here are the individual steps:
- hold the box as shown in the first picture. The screw head points upwards.
- now you must turn the box upside down. Now the nut points upwards (2nd picture). The ball falls from middle part into the slot on the top part.
- now turn the lower part towards you (3rd picture).
- turn the box back again. The screw head points upwards again (4th) picture.
- now the middle part can be pushed to the right (5th picture).
- the locking nozzle is free and the middle part can be turned to the side (6th picture).
To reactivate the box, go back the way you came.
