Introduction: Emergency Drinking Water Kit
This instructable shows how to use everyday items to make a water purifying container for emergencies. It is good for a situation where you might be stranded or just without water in any emergency. It starts with just a few items that you probably already have around the house.
Step 1: Materials
Things you will need to make an emergency water bucket:
1) A 5-gallon bucket or another similar sized container
2) A small towel or rag (in an emergency this could be a shirt or a rag also)
3) A cup or a smaller container that will fit easily inside the larger container or bucket
4)A plastic tarp or a large piece of plastic rap
5)A bungee cord, paracord, or other tie that fits around the larger container
6) A rock, about 1-2 inches in diameter, or another small, weighted object such as a few bolts or bolt nuts.
Step 2: How to Build the Kit
Putting the bucket kit together is very easy. It works by evaporation.
First, get the towel very wet and place it in the bottom of the larger container, wrapped around the bottom with a space in the center.
Place the smaller container in the middle of the towel.
Then, cover the larger container with the plastic and tie the outside to keep it sealed.
Place the rock (or another small, weighted object) in the center of the plastic directly above the smaller container.
The water from the towel will evaporate onto the plastic and drip off of the point that drops down because of the rock. This works the best in hot weather. The water that ends up in the cup will be much cleaner than the water stored in the towel since water leaves behind dirt and sediments when it evaporates.
See the introduction picture or the next slide for a diagram on how to put the kit together.
If you like this instructable, please vote for it in the survival contest! Thank you for reading.
Step 3: The Diagram.
Use the diagram as a reference if you need help putting the water bucket together.
