Introduction: Emergency LED Lamp
are you preparing for a storm or go camping or blackout? make an emergency light in just 5 to 10 minutes! the best part is that you can detach the lid turning it into a compact flashlight and this has a 360 degrees ray of light.
Step 1: Things That You Need
Materials:
-3W Led
-Jar ( that fits in the size of the battery)
-Red LED indicator
-BL-5C nokia battery
-IN4007 Rectifier diode
-470 ohm resistor
-on/off switch
-female DC socket
Tools:
-Soldering iron
-Glue gun
-Portable drill
-Glue stick
-Solder
Step 2: the Schematic Diagram
Step 3: Solder Everything in Place
Just follow the diagram and your good to go!
Step 4: Charge Testing
you can use any kind of wall wart to charge it just make sure it's output is 5V
Step 5: You're Done!
If you have questions for this instructable just write a comment.
